umbrel@umbrel:~ $ sudo ~/umbrel/scripts/debug
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : c03111
Serial : 10000000bf849b6a
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=43.8’C
Throttling
throttled=0x0
Mem: 3.8G 129M 3.0G 16M 696M 3.6G
Swap: 0B 0B 0B
total: 3.4%
system: 3.4%
Memory monitor logs
tail: cannot open ‘/home/umbrel/umbrel/scripts/../logs/memory-monitor.log’ for reading: No such file or directory
/dev/root 59G 3.1G 53G 6% /
Startup service logs
– Logs begin at Thu 2023-06-22 16:43:58 UTC, end at Mon 2023-09-11 09:03:39 UTC. –
Jun 22 16:44:16 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Jun 22 16:44:16 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Jun 22 16:44:04 umbrel systemd[1]: Starting External Storage Mounter…
Jun 22 16:44:04 umbrel external storage mounter[504]: Running external storage mount script…
Jun 22 16:44:07 umbrel external storage mounter[504]: Found device “Realtek RTL9210 NVME”
Jun 22 16:44:07 umbrel external storage mounter[504]: Blacklisting USB device IDs against UAS driver…
Jun 22 16:44:07 umbrel external storage mounter[504]: Rebinding USB drivers…
Jun 22 16:44:07 umbrel external storage mounter[504]: Checking USB devices are back…
Jun 22 16:44:07 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:08 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:09 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:10 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:11 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:12 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:13 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:14 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:15 umbrel external storage mounter[504]: Waiting for USB devices…
Jun 22 16:44:16 umbrel external storage mounter[504]: USB devices weren’t registered after 10 tries…
Jun 22 16:44:16 umbrel external storage mounter[504]: Exiting mount script without doing anything
Jun 22 16:44:16 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Jun 22 16:44:16 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Jun 22 16:44:16 umbrel systemd[1]: Failed to start External Storage Mounter.
Jun 22 16:44:16 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Jun 22 16:44:16 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor Proxy logs
==== Result ====
==== END =====
