Hi Umbrel Community,
I’m working on setting up a ZOOZ ZST10 S2 70 STICK
on my new Umbrel Home device runing Home Assistant. The stick is plugged in to the USB and shows up when I do lsusb in terminal as Silicon Labs CP210x UART Bridge.
From here on I can find no steps that define a procedure to configure the stick on Home Assistant. There are steps on Home Assistant’s own pages that require the use of Add-On store to host an instance of Z-Wave JS Server. However since Umbrel runs an instance of Core Home Assistant the Add-On store is not available. Therefore I must find another way to run an instance of Z-Wave JS Server* for the HA Z-Wave Integration to connect to.
I’m thinking of leveraging the built-in Portainer app on Umbrel to run the server and the zwavejs2mqtt application.
I’m curious if anyone else has taken a similar approach or has experience and would be willing to share their procedure?
Here’s the approach I’m considering. However I have no experience of Portainer, and am completely new to Umbrel and Home Assistant too:
- Create a
docker-compose.yaml file to deploy zwavejs2mqtt
- Run the container via
docker-compose up -d and access the zwavejs2mqtt web UI at http://<Umbrel-IP>:8091.
- Enable WebSocket Server in the web UI under the Home Assistant settings.
- Integrate with Home Assistant Core using the Z-Wave JS integration and connect to the WebSocket at
ws://<Umbrel-IP>:3000.
Thanks loads Ian
I made some good progress on this after finding the Home Automation Guy article on Installing Z-Wave JS with Home Assistant. I ran through it and found some deviations from the steps but on the whole it worked for me.
My initial step was to plug the USB stick into an Umbrel USB port and install Portainer app on Umbrel.
The next step is to SSH to umbrel@<umbrel_host>
In your terminal session:
- Execute sudo ls -la /dev/serial/by-id
- Check the listing and look for your device on the USB port - note the symlink:
- lrwxrwxrwx 1 root root 13 Dec 30 16:06 usb-Silicon_Labs_Zooz_ZST10_700_Z-Wave_Stick_0001-if00-port0 → …/…/ttyUSB0
- In my case the stick is located at /dev/ttyUSB0 - make a note of this path
- Next create a directory on the host for the container to use for config files:
- Execute sudo mkdir /mnt/root/data/zwavejs
- Execute sudo chmod -R 755 /mnt/root/data/zwavejs
That completes the actions on the Umbrel filesystem itself now create a Portainer ‘Stack’ (similar to Docker Compose)
- Open the Portainer app from your Umbrel home screen (UI URL = http://<umbrel_host>:9000)
- From the Portainer home screen (http://<umbrel_host>:9000/#!/home) click on the Primary Docker item in the Environments table
- From the left hand navigation menu click on Stacks to open the stacks page (http://<umbrel_host>:9000/#!/1/docker/stacks)
- Click Add Stack to open the Create Stack page
- In Create Stack leave the Web Editor open selected and past in the yaml below:
version: '3.7'
services:
zwavejs2mqtt:
container_name: zwavejs2mqtt
image: zwavejs/zwavejs2mqtt:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
- SESSION_SECRET=<GENERATE_A _RANDOM_STRING_FOR_THIS_VALUE>
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Uncomment the line below to set timezone
# - TZ=America/New_York
devices:
- '/dev/ttyUSB0:/dev/zwave'
volumes:
- /mnt/root/data/zwavejs:/usr/src/app/store
ports:
- "8091:8091"
- "3000:3000"
- Click Deploy the stack button on the Create Stack page
The container should now deploy but you might see errors or warnings in the log - you will need to keep the container up and use the Z-Wave JS UI to adjust the config
- Open the URL http://<umbrel_host>:8091 in a browser
- In the UI click on the Settings cog
- Under the Z-Wave section - check: Enabled = checked, Serial Port = /dev/zwave, and Config Priority Directory = /usr/src/app/store/config
- under the Home Assistant section - check WS Server = enabled
- Save any changes in the Z-Wave JS UI
Stop and Redeploy the Stack you created in Portainer and allow it to reinitialise.
You can now go to Home Assistant and Add the Z-Wave integration under Settings. In the Z-Wave integation dialog simply accept the default ws://localhost:3000 setting and submit.
With any luck you’ll have success in adding the Z-Wave integration at this point.
If anyone knows how to get the serial port specified by-id in the devices section of the YAML then I’d be interested to know. Docker doesn’t seem to like symlinks despite Home Automation Guy’s steps. The downside to not using the symlink USB device is you can’t simply move the stick from one USB port to another.
Correction To Stack YAML:
I spotted an error in the YAML of the Stack. The Volume mapping is incorrect, since Umbrel runs Portainer in it’s own Docker container then the filesystem on the underlying system is not the Umbrel filesystem but the file system of Docker. For that reason there needs to be a Volume creation step in Portainer that was missing from the original solution.
1) Add a New Volume in Portainer
In the Portainer UI open Volumes and create a new volume named with the following:
Mount Path: /data/data/volumes/zwavejs2mqtt/_data
2) Update the Stack YAML for zwavejs2mqtt container
The new Volume mapping is:
volumes:
- /data/data/volumes/zwavejs2mqtt/_data:/usr/src/app/store
The physical path to the mount point is therefore:
/home/umbrel/umbrel/app-data/portainer/data/docker/data/volumes/zwavejs2mqtt/_data/
