Hi all,
I just purchased an Umbrel and I’m excited to get started using it. I am looking at ordering some Z-Wave devices so that I can setup a security/alert system at home using Home Assistant. I have read that there are issues with Umbrel detecting a Z-Wave USB dongle. I’m curious, is there a work around for this or should I be using a different device to run HA on for this setup? I have another desktop computer that I could also use to act as the hub - is it possible to sync Home Assistant with the Umbrel from this other device? Thanks for your help!
