how to open umbrel using terminal? i know its an interface that you have to access through the web browser but how do i get there? i tried doing my ip and the umbrel port number but it said failed to connect. thanks
You can start Umbrel in WSL with ~/umbrel/scripts/start
Then access in your Browser on Windows via http://127.0.0.1
Check also some comments I wrote for WSL2: JAM - does it work for you? - #2 by hzrng
