I installed RTL and wanted to change some Node Configs. I alwayas get the response 400. I restarted the app and the Node. But still the same Error.
Http Failure Response For Http://umbrel.local:3001/rtl/api/conf/node: 400 Bad Request
I flushed my DNS and i tryed a different browser. Same Result.
Hi, I have the same issue here - have you found anything out?
yup i also see this issue in LND RTL
Update Node Settings Failed!
Error Code
400
Error Message
Http Failure Response For Http://umbrelip:3001/rtl/api/conf/node: 400 Bad Request
API URL
./api/conf/node
Same error only when i try to switch to dark mode theme, i’m unable to activate it, anyone know how to fix this?
Error Code
400
Error Message
Http Failure Response For Http://umbrel-2.local:3001/rtl/api/conf/node: 400 Bad Request
API URL
./api/conf/node
RTL-Node-1.log (13.1 KB)
