Can´t access lnd.conf
My node is setup & running well, already opened up a bunch of nice channels.
I am trying to set a minimum channel size for those wishing to connect with.
I understand I can do so in lnd.conf and this should be easily done for example using RTL under “Node Config”.
However when I try to aces LND Config (using RTL) and login with my password I do receive this error message:
Fetch Config Failed!
Error Code
500
Error Message
Reading Config Error
API URL
./api/conf/config/ln
Hi @Steve-Me
Please see the following. I will look into the RTL error further for you, I’m not currently certain on the cause.
Thank you so much! I have changed the min & max size of accepted channels using the Advanced settings in the Node app. Only out of curiosity: If you find out more on the RTL error let me know.
Thanks so much again!
We fixed it! https://github.com/getumbrel/umbrel-apps/tree/master/ride-the-lightning
You’ll need to update, but should be resolved for you now. Btw, it seems these settings are view-only from RTL
