Recovering Bitcoin Node funds
it seems my Rasp Pi is no longer working. Home network says it hasn’t connected in over 24 hours. I cannot connect using SSH. I have an on-chain balance in my bitcoin node wallet. I don’t remember ever being prompted for a recovery phrase for the wallet. I do have an Umbrel node recovery phrase, but I’m assuming I cannot create a new wallet using that seed phrase. Can anyone let me know how to recover funds from my bitcoin node wallet? or maybe try to fire up my Node again? The lights are on, the fan is running, but I cannot connect to it!
thanks
Hey! If we can SSH you can grab your seed phrase with this command:
sudo nano ~/umbrel/app-data/lightning/data/lightning/state.json
If you can’t access the Pi 4 firstly we’ll need to make sure the green light is flashing next to the red power on light, if it’s not follow steps here to reflash: https://umbrel.com/#start
Then let me know what else you’ve tried, we can likely get you connected - during this time avoid reformatting the drive we can likely at least grab the seed phrase off of it just in case
Do you remember when you had updated last? In the earlier versions the wallet was in Bitcoin Node and it’s moved to Lightning Node app for your LND Recovery Phrase, if you have this we can also likely perform an Automated Recovery if necesssary by entering it in after installing this is how that process looks demonstrated here
Feel free to post in the Help and Support channel on Telegram
Or can reach out to me directly too and I can assist you get up and running and recover easer in real-time
Hi Jim.
Thanks for your time. I had updated to the latest umbrel version. There is no green light like there normally is. Just a solid red light. I will try to SSH in again.
JH
Gotchya, you won’t be able to SSH if there is no green light so definitely should reflash the MicroSD card again let me know how it goes! Got my Telegram here too whenever or you can Twitter DM me or the official Umbrel account too if that’s easier for you to message immediatley instead of post on forum
reflashed microSD. umbrel is now appearing on my laptop again, but both bitcoin node & lightning node apps will not open. It seems like they’re about to open but they just will not sync
Could you share a debug log?
For reference check out FAQ under “Generating Troubleshooting Logs” here: Official Umbrel Troubleshooting Guide and FAQ - Guides - Umbrel Community
You can also just use the interface as the article describes via going System > Troubleshoot > Start and it will generate it from you right there within the dashboard and download it, then you can share it from www.pastebin.com and paste a link
If for any reason you are unable to generate from the UI
You can SSH via the steps from “How to SSH” for reference in the guide and copy the output of this command for the log:
sudo ~/umbrel/scripts/debug
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : d03114
Serial : 1000000064f19306
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=54.0’C
Throttling
throttled=0x0
Mem: 7.8G 4.7G 1.0G 377M 2.1G 2.6G
Swap: 4.1G 3.1G 955M
total: 60.1%
system: 35.6%
mempool: 10.2%
lightning: 5%
electrs: 4.4%
lightning-terminal: 2.3%
bitcoin: 1.4%
vaultwarden: 0.6%
snowflake: 0.6%
Memory monitor logs
2022-10-13 17:33:38 Warning memory usage at 95%
2022-12-12 22:07:07 Memory monitor running!
2022-12-12 22:15:17 Memory monitor running!
2022-12-27 18:33:41 Memory monitor running!
2023-04-10 00:13:42 Memory monitor running!
3058 ? S 2:57 bash ./scripts/memory-monitor
2023-06-21 23:07:51 Memory monitor running!
2023-07-03 20:39:27 Memory monitor running!
2023-07-03 21:34:28 Memory monitor running!
/dev/root 30G 4.2G 24G 15% /
/dev/sda1 916G 624G 246G 72% /home/umbrel/umbrel
Startup service logs
– Logs begin at Sat 2023-07-15 12:47:36 UTC, end at Sun 2023-07-16 19:47:09 UTC. –
Jul 16 19:39:16 umbrel passwd[26679]: pam_unix(passwd:chauthtok): password changed for umbrel
Jul 16 19:42:21 umbrel passwd[6165]: pam_unix(passwd:chauthtok): password changed for umbrel
Jul 16 19:44:50 umbrel passwd[15351]: pam_unix(passwd:chauthtok): password changed for umbrel
Jul 16 19:45:33 umbrel passwd[17715]: pam_unix(passwd:chauthtok): password changed for umbrel
External storage service logs
– No entries –
– No entries –
Karen logs
Pulling electrs … digest: sha256:f215ca7163a3bd42ae…
Pulling electrs … status: downloaded newer image fo…
Pulling electrs … done
Starting app electrs…
Executing hook: /home/umbrel/umbrel/app-data/electrs/hooks/pre-start
Creating lightning-terminal_web_1 …
Creating lightning-terminal_app_proxy_1 …
Creating lightning-terminal_tor_server_1 …
Creating electrs_tor_server_1 …
Creating electrs_electrs_1 …
Creating lightning-terminal_web_1 … done
Creating electrs_tor_1 …
Creating electrs_app_proxy_1 …
Creating lightning-terminal_app_proxy_1 … done
Creating lightning-terminal_tor_server_1 … done
Creating electrs_app_proxy_1 … done
Creating electrs_tor_server_1 … done
Creating electrs_tor_1 … done
Creating electrs_electrs_1 … done
Creating electrs_app_1 …
Untagged: lightninglabs/lightning-terminal:v0.10.1-alpha@sha256:3e25ececbb127f975d414f2a81506fe688046cd26bf548112bb1e232e1d571eb
Deleted: sha256:816e3aeeb2ee57880e9a2f36d54757bd89946f9a537626cac94935736d72dbb9
Deleted: sha256:daaf0586334b57506ad69b76ef08f740606e9c53e14fd9087c90014b034c48c9
Deleted: sha256:20fb77a24f2a67399ce611022fd8d124dcb0400c60851e04a540f3d41ebc54aa
Deleted: sha256:8042a75a44410518b3bb92fe99af49d6fccd37ccbe31410e1e1dfcc9f439e758
Deleted: sha256:80f1ad73a4cf6c326681565bbdbce05f1c341990d32115d45eb9e6138168f2ef
Deleted: sha256:ca97ebba28d98071cff17f8feb479d72c70537de7710d8b072497efe5c80cb67
Deleted: sha256:fb773fc8954a2e1bd684f8049a4709d9990c1f9dcd034fa33f9ac722eed314ee
Deleted: sha256:233a6547564ce5b4b522a527c3842bf4c29e4610fbc8d787bbc389e4aaf4cc02
Deleted: sha256:cc21d797dac5d2385f360a2e400ac453c99b99c3b2bbd2700e6123ee76d3b44b
Creating electrs_app_1 … done
Untagged: getumbrel/electrs:v0.9.10@sha256:7b64bf93f2137fcd040fc512a302abda17dd1b4cad8181a14fa34c15361f1334
Deleted: sha256:c2ef36de8eaa79c8e4269b1447f21f49ecbf5b444ee73cfb8a3aeabf5ac3386e
Deleted: sha256:8247e8eac8cd9151d0e41312f52e960c2b2d512f361c79c5f5eea1a145e58308
Deleted: sha256:a39fda8bc72e57708a9953011324d9e6065ca645947f138cc49d0d7cb1d3e419
Deleted: sha256:700a2417b36bd0fab057070338f607fa5b7a7fe709868b05ac6571aaf652ddd7
Deleted: sha256:d862f0dab9f3f61f6a8a8084b6fbfd852a2fa5a57e72fc5b10a024a87dbbb90c
Error response from daemon: conflict: unable to remove repository reference “getumbrel/umbrel-electrs:v1.0.2@sha256:3dae686b22b1fdfd72ff058d022045f96cc5116e76f82f435d58f1cfe8f46418” (must force) - container e306e3d6f85a is using its referenced image 07d2927cee6f
Error response from daemon: conflict: unable to remove repository reference “getumbrel/tor:0.4.7.8@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a” (must force) - container 3c36d74e486f is using its referenced image 105438dd043f
Got signal: change-password
karen is getting triggered!
Got signal: debug
Docker containers
NAMES STATUS
electrs_app_1 Up 6 minutes
electrs_electrs_1 Up 12 seconds
electrs_tor_1 Up 6 minutes
electrs_app_proxy_1 Up 6 minutes
electrs_tor_server_1 Up 6 minutes
lightning-terminal_tor_server_1 Up 6 minutes
lightning-terminal_app_proxy_1 Up 6 minutes
lightning-terminal_web_1 Up 6 minutes
lightning_tor_1 Up 6 minutes
lightning_app_1 Up 6 minutes
lightning_tor_server_1 Up 6 minutes
lightning_app_proxy_1 Up 6 minutes
lightning_lnd_1 Up 6 minutes
bitcoin_server_1 Up 12 days
snowflake_tor_server_1 Up 12 days
snowflake_web_1 Up 12 days
snowflake_proxy_1 Up 12 days
snowflake_app_proxy_1 Up 12 days
bitcoin_i2pd_daemon_1 Up 12 days
bitcoin_bitcoind_1 Restarting (1) 29 seconds ago
bitcoin_tor_server_1 Up 12 days
bitcoin_tor_1 Up 12 days
bitcoin_app_proxy_1 Up 12 days
vaultwarden_server_1 Up 12 days (healthy)
vaultwarden_tor_server_1 Up 12 days
vaultwarden_app_proxy_1 Up 12 days
mempool_app_proxy_1 Up 12 days
mempool_tor_server_1 Up 12 days
mempool_web_1 Up 12 days
mempool_api_1 Up 10 seconds
mempool_mariadb_1 Up 12 days
nginx Up 12 days
tor_proxy Up 12 days
auth Up 12 days
tor_server Up 12 days
manager Up 12 days
dashboard Up 12 days
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:08 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:10 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:12 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:13 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:15 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:17 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:17 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:18 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:20 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
manager | ::ffff:10.21.21.2 - - [Sun, 16 Jul 2023 19:47:22 GMT] “GET /v1/system/debug-result HTTP/1.0” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Jul 16 03:34:50.000 [notice] While bootstrapping, fetched this many bytes: 632173 (consensus network-status fetch); 14101 (authority cert fetch); 8540696 (microdescriptor fetch)
tor_proxy | Jul 16 03:34:50.000 [notice] While not bootstrapping, fetched this many bytes: 13954349 (consensus network-status fetch); 104724 (authority cert fetch); 14203559 (microdescriptor fetch)
tor_proxy | Jul 16 05:09:48.000 [notice] Application request when we haven’t used client functionality lately. Optimistically trying directory fetches again.
tor_proxy | Jul 16 09:34:50.000 [notice] Heartbeat: Tor’s uptime is 12 days 12:00 hours, with 0 circuits open. I’ve sent 13.17 MB and received 50.75 MB. I’ve received 46 connections on IPv4 and 0 on IPv6. I’ve made 337 connections with IPv4 and 0 with IPv6.
tor_proxy | Jul 16 09:34:50.000 [notice] While bootstrapping, fetched this many bytes: 632173 (consensus network-status fetch); 14101 (authority cert fetch); 8540696 (microdescriptor fetch)
tor_proxy | Jul 16 09:34:50.000 [notice] While not bootstrapping, fetched this many bytes: 14106791 (consensus network-status fetch); 104724 (authority cert fetch); 14905963 (microdescriptor fetch)
tor_proxy | Jul 16 15:34:50.000 [notice] Heartbeat: Tor’s uptime is 12 days 18:00 hours, with 0 circuits open. I’ve sent 13.63 MB and received 51.44 MB. I’ve received 48 connections on IPv4 and 0 on IPv6. I’ve made 346 connections with IPv4 and 0 with IPv6.
tor_proxy | Jul 16 15:34:50.000 [notice] While bootstrapping, fetched this many bytes: 632173 (consensus network-status fetch); 14101 (authority cert fetch); 8540696 (microdescriptor fetch)
tor_proxy | Jul 16 15:34:50.000 [notice] While not bootstrapping, fetched this many bytes: 14255646 (consensus network-status fetch); 106497 (authority cert fetch); 14993972 (microdescriptor fetch)
tor_proxy | Jul 16 18:28:53.000 [warn] Received http status code 404 (“Not found”) from server 23.132.184.67:9000 while fetching “/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97”.
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_i2pd_daemon_1, bitcoin_bitcoind_1, bitcoin_tor_server_1, bitcoin_tor_1, bitcoin_app_proxy_1
app_proxy_1 | Validating token: 46738f46ef90 …
i2pd_daemon_1 | 19:17:43@67/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 19:18:36@714/error - Tunnel: Tunnel with id 3615583273 already exists
i2pd_daemon_1 | 19:28:33@634/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 19:41:01@145/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 19:41:09@634/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 19:42:36@634/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 19:42:37@634/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 19:43:22@145/error - Garlic: Can’t handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 19:44:45@714/error - Tunnels: Can’t select next hop for rwDV9CuQgrybnSqujEi5jPfFDLrErhFJORD0y4AKhNY=
i2pd_daemon_1 | 19:44:45@714/error - Tunnels: Can’t create inbound tunnel, no peers available
tor_1 | Jul 16 10:09:34.000 [warn] Received http status code 404 (“Not found”) from server 162.55.91.19:443 while fetching “/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97”.
tor_1 | Jul 16 10:10:39.000 [notice] No circuits are opened. Relaxed timeout for circuit 17688 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [5 similar message(s) suppressed in last 22380 seconds]
tor_1 | Jul 16 12:36:39.000 [notice] No circuits are opened. Relaxed timeout for circuit 17835 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 8760 seconds]
tor_1 | Jul 16 13:56:39.000 [notice] No circuits are opened. Relaxed timeout for circuit 17886 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 4800 seconds]
tor_1 | Jul 16 15:35:15.000 [notice] Heartbeat: Tor’s uptime is 12 days 18:00 hours, with 15 circuits open. I’ve sent 250.81 MB and received 214.50 MB. I’ve received 0 connections on IPv4 and 0 on IPv6. I’ve made 156 connections with IPv4 and 0 with IPv6.
tor_1 | Jul 16 15:35:15.000 [notice] While bootstrapping, fetched this many bytes: 632173 (consensus network-status fetch); 14354 (authority cert fetch); 8540890 (microdescriptor fetch)
tor_1 | Jul 16 15:35:15.000 [notice] While not bootstrapping, fetched this many bytes: 8237231 (consensus network-status fetch); 61668 (authority cert fetch); 15694621 (microdescriptor fetch)
tor_1 | Jul 16 17:49:41.000 [notice] No circuits are opened. Relaxed timeout for circuit 18075 (a Hidden service: Uploading HS descriptor 4-hop circuit in state doing handshakes with channel state open) to 60000ms. However, it appears the circuit has timed out anyway. [1 similar message(s) suppressed in last 14040 seconds]
tor_1 | Jul 16 18:59:46.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60000ms after 18 timeouts and 1000 buildtimes.
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.10 - - [Sun, 16 Jul 2023 19:44:20 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
server_1 |
server_1 | ::ffff:10.21.0.10 - - [Sun, 16 Jul 2023 19:44:26 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
server_1 |
server_1 | ::ffff:10.21.0.10 - - [Sun, 16 Jul 2023 19:44:29 GMT] “GET /v1/bitcoind/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
server_1 |
bitcoind_1 | Error: Settings file could not be read:
bitcoind_1 | - Unable to parse settings file /data/.bitcoin/settings.json
electrs
Attaching to electrs_app_1, electrs_electrs_1, electrs_tor_1, electrs_app_proxy_1, electrs_tor_server_1
app_proxy_1 | [HPM] Proxy created: / → http://10.21.22.4:3006
app_proxy_1 | Waiting for 10.21.22.4:3006 to open…
app_proxy_1 | Electrs is now ready…
app_proxy_1 | Listening on port: 2102
app_1 | > umbrel-electrs@1.0.1 dev:backend
app_1 | > npm run start -w umbrel-electrs-backend
app_1 |
app_1 |
app_1 | > umbrel-electrs-backend@0.1.12 start
app_1 | > node ./bin/www
app_1 |
app_1 | Sun, 16 Jul 2023 19:41:12 GMT morgan deprecated morgan(options): use morgan(“default”, options) instead at app.js:28:9
app_1 | Sun, 16 Jul 2023 19:41:12 GMT morgan deprecated default format: use combined format at app.js:28:9
app_1 | Listening on port 3006
electrs_1 | Error: electrs failed
electrs_1 |
electrs_1 | Caused by:
electrs_1 | 0: failed to open bitcoind cookie file: /data/.bitcoin/.cookie
electrs_1 | 1: No such file or directory (os error 2)
electrs_1 | Starting electrs 0.9.14 on aarch64 linux with Config { network: Bitcoin, db_path: “/data/db/bitcoin”, daemon_dir: “/data/.bitcoin”, daemon_auth: CookieFile(“/data/.bitcoin/.cookie”), daemon_rpc_addr: 10.21.21.8:8332, daemon_p2p_addr: 10.21.21.8:8333, electrum_rpc_addr: 0.0.0.0:50001, monitoring_addr: 127.0.0.1:4224, wait_duration: 10s, jsonrpc_timeout: 15s, index_batch_size: 10, index_lookup_limit: None, reindex_last_blocks: 0, auto_reindex: true, ignore_mempool: false, sync_once: false, skip_block_download_wait: false, disable_electrum_rpc: false, server_banner: “Umbrel Electrs (0.9.10)”, signet_magic: f9beb4d9, args: }
electrs_1 | [2023-07-16T19:47:22.566Z INFO electrs::metrics::metrics_impl] serving Prometheus metrics on 127.0.0.1:4224
electrs_1 | [2023-07-16T19:47:22.566Z INFO electrs::server] serving Electrum RPC on 0.0.0.0:50001
electrs_1 | [2023-07-16T19:47:22.666Z INFO electrs::db] “/data/db/bitcoin”: 171 SST files, 41.249792485 GB, 5.170234359 Grows
electrs_1 | [2023-07-16T19:47:29.664Z INFO electrs::chain] loading 795233 headers, tip=000000000000000000008e4cdb0d268b551dee70ba944b8cc57c4c3e13120da4
tor_1 | Jul 16 19:41:05.000 [notice] Bootstrapped 56% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 16 19:41:07.000 [notice] Bootstrapped 64% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 16 19:41:08.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 16 19:41:08.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Jul 16 19:41:09.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Jul 16 19:41:09.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Jul 16 19:41:09.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Jul 16 19:41:09.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 16 19:41:09.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Jul 16 19:41:09.000 [notice] Bootstrapped 100% (done): Done
lightning
Attaching to lightning_tor_1, lightning_app_1, lightning_tor_server_1, lightning_app_proxy_1, lightning_lnd_1
app_1 | ::ffff:10.21.0.5 - - [Sun, 16 Jul 2023 19:45:47 GMT] “GET /v1/lnd/info/status HTTP/1.1” 200 38 “-” “Mozilla/5.0 (Windows NT 10.0; rv:102.0) Gecko/20100101 Firefox/102.0”
app_1 |
app_1 | umbrel-lightning
app_1 | Checking LND status…
app_1 | Waiting for LND…
app_proxy_1 | Validating token: 4cbe604eb47c …
app_1 | [backup-monitor] Checking channel backup…
app_1 | [backup-monitor] Sleeping…
tor_1 | Jul 16 19:40:51.000 [notice] Bootstrapped 57% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 16 19:40:52.000 [notice] Bootstrapped 64% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 16 19:40:53.000 [notice] Bootstrapped 69% (loading_descriptors): Loading relay descriptors
tor_1 | Jul 16 19:40:53.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Jul 16 19:40:54.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Jul 16 19:40:54.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Jul 16 19:40:55.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Jul 16 19:40:55.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Jul 16 19:40:55.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Jul 16 19:40:55.000 [notice] Bootstrapped 100% (done): Done
lnd_1 | 2023-07-16 19:45:57.204 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:45:57.219 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:46:18.187 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:46:18.206 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:46:38.789 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:46:38.809 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:47:04.482 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:47:04.532 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:47:31.586 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lnd_1 | 2023-07-16 19:47:31.615 [ERR] RPCS: [/lnrpc.Lightning/DescribeGraph]: wallet locked, unlock it to enable full RPC access
lightning-terminal
Attaching to lightning-terminal_tor_server_1, lightning-terminal_app_proxy_1, lightning-terminal_web_1
app_proxy_1 | [HPM] Proxy created: / → http://lightning-terminal_web_1:3004
app_proxy_1 | Waiting for lightning-terminal_web_1:3004 to open…
app_proxy_1 | Lightning Terminal is now ready…
app_proxy_1 | Listening on port: 3004
web_1 | LiT Version 0.10.2-alpha commit=v0.10.2-alpha
web_1 | Web interface 127.0.0.1:8443, 0.0.0.0:3004 (open https://127.0.0.1:8443 or http://localhost:3004 in your browser)
web_1 | ----------------------------------------------------------
web_1 | 2023-07-16 19:40:47.575 [INF] LITD: Connecting basic lnd client
web_1 | 2023-07-16 19:40:47.778 [INF] LITD: Connecting full lnd client
web_1 | 2023-07-16 19:40:47.778 [INF] LNDC: Creating lnd connection to 10.21.21.9:10009
web_1 | 2023-07-16 19:40:47.779 [INF] LNDC: Connected to lnd
web_1 | 2023-07-16 19:40:47.804 [INF] LNDC: Waiting for lnd to unlock
web_1 | 2023-07-16 19:40:47.828 [INF] LNDC: Wallet state of lnd is now: Lnd is waiting to start
web_1 | 2023-07-16 19:40:53.727 [INF] LNDC: Wallet state of lnd is now: Wallet is locked
mempool
Attaching to mempool_app_proxy_1, mempool_tor_server_1, mempool_web_1, mempool_api_1, mempool_mariadb_1
api_1 | at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1187:16) {
api_1 | errno: -113,
api_1 | code: ‘EHOSTUNREACH’,
api_1 | syscall: ‘connect’,
api_1 | address: ‘10.21.21.8’,
api_1 | port: 8332
api_1 | }
api_1 | wait-for-it.sh: waiting 720 seconds for mariadb:3306
api_1 | wait-for-it.sh: mariadb:3306 is available after 0 seconds
api_1 | Jul 16 19:47:39 [110] NOTICE: Starting Mempool Server… (57eddac)
web_1 | /var/www/mempool/browser/resources
mariadb_1 | 2023-07-16 19:46:00 93535 [Warning] Aborted connection 93535 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-16 19:46:01 93536 [Warning] Aborted connection 93536 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-16 19:46:21 93537 [Warning] Aborted connection 93537 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-16 19:46:22 93538 [Warning] Aborted connection 93538 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-16 19:46:42 93539 [Warning] Aborted connection 93539 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-16 19:46:43 93540 [Warning] Aborted connection 93540 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-16 19:47:08 93541 [Warning] Aborted connection 93541 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-16 19:47:09 93542 [Warning] Aborted connection 93542 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-07-16 19:47:35 93543 [Warning] Aborted connection 93543 to db: ‘mempool’ user: ‘mempool’ host: ‘10.21.21.27’ (Got an error reading communication packets)
mariadb_1 | 2023-07-16 19:47:36 93544 [Warning] Aborted connection 93544 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
app_proxy_1 | [HPM] Client disconnected
app_proxy_1 | [HPM] Upgrading to WebSocket
snowflake
Attaching to snowflake_tor_server_1, snowflake_web_1, snowflake_proxy_1, snowflake_app_proxy_1
proxy_1 | 2023/07/16 19:42:25 Generating answer…
proxy_1 | 2023/07/16 19:42:51 Timed out waiting for client to open data channel.
proxy_1 | 2023/07/16 19:43:21 sdp offer successfully received.
proxy_1 | 2023/07/16 19:43:21 Generating answer…
proxy_1 | 2023/07/16 19:43:46 Timed out waiting for client to open data channel.
proxy_1 | 2023/07/16 19:44:57 sdp offer successfully received.
proxy_1 | 2023/07/16 19:44:57 Generating answer…
proxy_1 | 2023/07/16 19:45:23 Timed out waiting for client to open data channel.
proxy_1 | 2023/07/16 19:47:25 sdp offer successfully received.
proxy_1 | 2023/07/16 19:47:25 Generating answer…
app_proxy_1 | [HPM] Proxy created: / → http://snowflake_web_1:3800
app_proxy_1 | Waiting for snowflake_web_1:3800 to open…
app_proxy_1 | Tor Snowflake Proxy is now ready…
app_proxy_1 | Listening on port: 3800
web_1 | 2023/07/03 21:35:17 Using index file at /snowflake/index.html
web_1 | 2023/07/03 21:35:17 Server is starting with command: bash -c tail -n 10000 -f /snowflake/snowflake.log | grep “Traffic Relayed”
web_1 | 2023/07/03 21:35:17 URL: http://127.0.0.1:3800/
web_1 | 2023/07/03 21:35:17 URL: http://10.21.0.20:3800/
vaultwarden
Attaching to vaultwarden_server_1, vaultwarden_tor_server_1, vaultwarden_app_proxy_1
app_proxy_1 | [HPM] Proxy created: / → http://10.21.21.46:8089
app_proxy_1 | Waiting for 10.21.21.46:8089 to open…
app_proxy_1 | Vaultwarden is now ready…
app_proxy_1 | Listening on port: 8089
server_1 | | official channels to report bugs/features, regardless of client. |
server_1 | | Send usage/configuration questions or feature requests to: |
server_1 | | https://vaultwarden.discourse.group/ |
server_1 | | Report suspected bugs/issues in the software itself at: |
server_1 | | Sign in to GitHub · GitHub |
server_1 | --------------------------------------------------------------------/
server_1 |
server_1 | [INFO] No .env file found.
server_1 |
server_1 | [2023-07-03 21:35:12.009][start][INFO] Rocket has launched from http://0.0.0.0:8089
==== Result ====
I lost about $585,000.00 USD to a fake cryptocurrency trading platform a few weeks back after I got lured into the trading platform with the intent of earning a 15% profit daily trading on the platform. It was a hell of a time for me as I could hardly pay my bills and got me ruined financially. I had to confide in a close friend of mine who then introduced me to this crypto recovery team with the best recovery CYBERPOINT Recovery i contacted them and they were able to completely recover my stolen digital assets with ease. Their service was superb, and my problems were solved in swift action, It only took them 48 hours to investigate and track down those scammers and my funds were returned to me. I strongly recommend this team to anyone going through a similar situation with their investment or fund theft to look up this team for the best appropriate solution to avoid losing huge funds to these scammers. Send complaint to E.m.a.i.l: (Support (at) cyberpointrecovery (dot) c om)
