Raspberry Pi 5 Won't Boot Anymore
My Raspberry Pi 5 won’t boot Umbrel any more. I get the following which I can’t interrupt.
That probably is some ethernet related issue. Maybe try using another cable or connect it to USB port via USB→ethernet adapter.
Also make sure you are using the official Raspberry Pi power supply.
Let me know if this helped.
Different cable didn’t help. Both cables work find with different R-Pis.
I am using an official power supply.
Have you tried reflashing the SD card with latest umbrelOS?
@Django I reflashed the microSD card and the system now boots and is running.
My uSD card is16GB and the Umbrel site says I need a 32GB+ card. Would this be why my Raspberry Pi 5 sometimes stops? I also have a 1TB SSD connected to my RP 5 and I am running a Bitcoin node.
It could be. SD cards are also very sensible to power outages so be careful of that.
Do you really need a 32GB microSD card?
My RP is plugged into a UPS so power outages should not be a problem.
