I setup a Raspberry Pi 4 2gig with Umbrel the other day. The only app I have installed is the Bitcoin Node app which is currently syncing to the blockchain. Today I powered everything down, swapped out the Raspberry Pi 4 2gig for a 8gig model. I took the Micro SD card from the 2 gig model and put it into the 8 gig model, connected my SSD, and powered on the Rasberry Pi.
Everything is working great, the Bitcoin Node is syncing, System Settings shows 8.2 gigs. The issue I have is when I click “View Usage” under the RAM tab the System shows “Calculating…”. The Raspberry Pi has been running for six hours. If I click “Start” under Troubleshoot to see the log, RAM System usage shows 0%.
Did I do something wrong? How do I fix this?
