Is there an App that allows me to see the CPU + RAM + STORAGE usage ? Im using a Raspberry Pi 4 With 4 Gb Ram. Im running only the Bitcoin node and i would like to see whats bottlenecking and where i can improve my setup.
Thanks
Thanks
You could also check out Grafana in the Umbrel AppStore. Grafana provides powerful visualizations for monitoring CPU and RAM usage, enabling real-time insights into system performance. It integrates with data sources like Prometheus for detailed resource tracking.
Brilliant thanks, Will check this out !
Upgrading Umbrel might be the easiest solution to see that as danny mentioned.
Other than that, for just a Bitcoin node you shouldn’t have any kind of problem/bottleneck using a Raspberry Pi 4 4gb, do you notice any low performance overall?
Yes i only Sync 1% a day of the bitcoin core … 100 days to sync the core feels like a very long time considering it’s only 550 ish GB download. I should update to the newer version but i dont want any other issues at the moment .
Are you syncing it just using TOR peers? that might be it
All 3 connections
Outgoing Connections to I2P Peers
Outgoing Connections to Clearnet Peers
Outgoing Connections to Tor Peers
