Questions regarding Updating from 0.5 to 1.1 on linux
i have a mini pc with debian that runs an umbrel instance that was installed via script.
I configured a raid1 setup and umrel is installed on the raid array consisting of 2 external ssds.
I also have wireguard set up to connect to my vps for clearnet/hybrid routing.
Concering the migration i have these questions:
  1. umbrel 1.0 is based on debian, right? will i be able to configure stuff like wireguard on the os separate from the umbrel instance like i have now?
  2. is the umbrel installer able to create raid arrays? or are there any issues when setting up a raid array after the standard install/data migration?
