Question about Umbrel apps?
I’m interested in knowing whether it’s possible to self-host my own applications on Umbrel. Specifically, I’d like to understand if it’s feasible to do this using something like the Safe interface? Would it be possible to turn this into a functional, usable app on Umbrel for personal use, or would I need to go through the official listing process to make it work?
you’ve got full admin rights and can spin up your own persistent docker container. :slight_smile:
Thank you for the reply! :slight_smile:
in '23 I needed InfluxDB which was unavailable at that time on Umbrel so I used the “Umbrel Community App Store Template”
See if it works for you.
