Hello !
I have a problem when installing Umbrel, I can’t get my external hard drive to work, this one is a USB 2.0 HDD;
Tried it:
Reinstall umbrel on the sd card
Try different USB ports ( 2.0 and 3.0 )
Unplug all other usb cables
Here is my hardware:
- Raspberry Pi 4 model B - 8GB, 32 GB SD Card
- WD Elements SE Portable ( https://www.amazon.fr/Elements-Portable-WDBABV5000ABK-Disque-externe/dp/B004I5TB9E )
and to finish the logfile :
I thank you in advance for any help
