"Please check the Node ID" - can't input a Node ID
Hi there,
I’m new to Lightning, and attempting to open channels.
I read this article but can’t find a solution.
I tried for instance, to open a channel with ACINC node, but I get the message : “Please check the Node ID (also known as peer address)”
The channel size I’m trying is 30 000 sats, which I know is low, but I can’t imagine that the problem is related.
Do you know how can I proceed?
Thank you,
RH
For the posterity: my amount of sats was too low and at first i was not inputing a Tor node, although im using Tor.
It works now.
