Pi-Hole with unbound running on umbrel?
Any1 has successfully running Pi-Hole with unbound on umbrel? Not sure if I should try Unbound or not. How did you install it? Just SSH in the server and install and hope for the best?
Pi-Hole is running great so far - but unbound would be a nice addition.
Hi, yes I just installed Unbound via SSH as described in pi-hole’s docs.
I then also activated the cache for unbound. This is somewhat redundant, as pi-hole already caches, but I was still able to significantly reduce the load on the cpu.
You may also be interested in Cloudflared
That actually looks very interesting. But do I see that correctly: Cloudflared makes umbrel visible to everyone via a public domain?
Or does it work in a similar way to a VPN, only the entry point works via a public domain?
At the moment I use tailscale and use umbrel as DNS server. That way I can use Pi-hole from anywhere and don’t have to make anything publicly accessible.
Only the apps you enable!
Hi how you ssh? In your regular computer you ssh into the umbrel OS? Is your umbrel OS installed on a raspberry pi device?
ssh umbrel@umbrel.local and the password you define for umbrel. Yes in a pi5
Umbrel 1.4 one additional step install dig
sudo apt update && sudo apt install dnsutils -y
