Pb installing an umbrel node
Hi everybody,
I am trying to install an umbrel node on a raspb pi4, but it doesn’t work!
When I run debug I have the following :
0.5.3
Flashed OS version
v0.5.3
Raspberry Pi Model
Revision : d03115
Serial : 10000000303b51e4
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=33.1’C
Throttling
throttled=0x0
Mem: 7.8G 116M 7.5G 8.0M 232M 7.6G
Swap: 4.1G 0B 4.1G
total: 1.5%
system: 1.5%
Memory monitor logs
/dev/root 15G 2.9G 11G 22% /
/dev/sda1 1.8T 5.3G 1.7T 1% /home/umbrel/umbrel
Startup service logs
Jan 15 09:39:18 umbrel umbrel startup[2609]: docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
Jan 15 09:39:18 umbrel umbrel startup[2609]: See ‘docker run --help’.
Jan 15 09:39:18 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=125/n/a
Jan 15 09:39:18 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jan 15 09:39:18 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jan 15 09:39:28 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jan 15 09:39:28 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 16.
Jan 15 09:39:28 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jan 15 09:39:28 umbrel systemd[1]: Starting Umbrel Startup Service…
Jan 15 09:39:28 umbrel umbrel startup[2707]: ======================================
Jan 15 09:39:28 umbrel umbrel startup[2707]: ============ CONFIGURING =============
Jan 15 09:39:28 umbrel umbrel startup[2707]: ========= UMBREL (mainnet) ===========
Jan 15 09:39:28 umbrel umbrel startup[2707]: Generating auth credentials
Jan 15 09:39:28 umbrel umbrel startup[2707]: Generating Tor password
Jan 15 09:39:29 umbrel umbrel startup[2707]: docker: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?.
Jan 15 09:39:29 umbrel umbrel startup[2707]: See ‘docker run --help’.
Jan 15 09:39:29 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=125/n/a
Jan 15 09:39:29 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jan 15 09:39:29 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jan 15 09:39:39 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jan 15 09:39:39 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 17.
Jan 15 09:39:39 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jan 15 09:39:39 umbrel systemd[1]: Starting Umbrel Startup Service…
Jan 15 09:39:39 umbrel umbrel startup[2814]: ======================================
Jan 15 09:39:39 umbrel umbrel startup[2814]: ============ CONFIGURING =============
Jan 15 09:39:39 umbrel umbrel startup[2814]: ========= UMBREL (mainnet) ===========
Jan 15 09:39:39 umbrel umbrel startup[2814]: Generating auth credentials
Jan 15 09:39:39 umbrel umbrel startup[2814]: Generating Tor password
External storage service logs
Jan 15 09:35:58 umbrel external storage mounter[482]: Found device “Lexar SS D NM610PRO 2TB”
Jan 15 09:35:58 umbrel external storage mounter[482]: Blacklisting USB device IDs against UAS driver…
Jan 15 09:35:58 umbrel external storage mounter[482]: Rebinding USB drivers…
Jan 15 09:35:58 umbrel external storage mounter[482]: Checking USB devices are back…
Jan 15 09:35:58 umbrel external storage mounter[482]: Waiting for USB devices…
Jan 15 09:35:59 umbrel external storage mounter[482]: Waiting for USB devices…
Jan 15 09:36:00 umbrel external storage mounter[482]: Waiting for USB devices…
Jan 15 09:36:01 umbrel external storage mounter[482]: Waiting for USB devices…
Jan 15 09:36:02 umbrel external storage mounter[482]: Checking if the device is ext4…
Jan 15 09:36:03 umbrel external storage mounter[482]: Yes, it is ext4
Jan 15 09:36:03 umbrel external storage mounter[482]: Checking filesystem for corruption…
Jan 15 09:36:03 umbrel external storage mounter[482]: e2fsck 1.44.5 (15-Dec-2018)
Jan 15 09:36:04 umbrel external storage mounter[482]: umbrel: clean, 79771/122101760 files, 9296012/488378368 blocks
Jan 15 09:36:04 umbrel external storage mounter[482]: Mounting partition…
Jan 15 09:36:04 umbrel external storage mounter[482]: Checking if device contains an Umbrel install…
Jan 15 09:36:04 umbrel external storage mounter[482]: Yes, it contains an Umbrel install
Jan 15 09:36:04 umbrel external storage mounter[482]: Bind mounting external storage over local Umbrel installation…
Jan 15 09:36:04 umbrel external storage mounter[482]: Bind mounting external storage over local Docker data dir…
Jan 15 09:36:04 umbrel external storage mounter[482]: Bind mounting external storage to /swap
Jan 15 09:36:04 umbrel external storage mounter[482]: Bind mounting SD card root at /sd-card…
Jan 15 09:36:04 umbrel external storage mounter[482]: Checking Umbrel root is now on external storage…
Jan 15 09:36:05 umbrel external storage mounter[482]: Checking /var/lib/docker is now on external storage…
Jan 15 09:36:05 umbrel external storage mounter[482]: Checking /swap is now on external storage…
Jan 15 09:36:05 umbrel external storage mounter[482]: Setting up swapfile
Jan 15 09:36:05 umbrel external storage mounter[482]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jan 15 09:36:05 umbrel external storage mounter[482]: no label, UUID=201b9f73-c367-4965-bfd3-c75f4401a82d
Jan 15 09:36:05 umbrel external storage mounter[482]: Checking SD Card root is bind mounted at /sd-root…
Jan 15 09:36:05 umbrel external storage mounter[482]: Starting external drive mount monitor…
Jan 15 09:36:05 umbrel external storage mounter[482]: Mount script completed successfully!
Jan 15 09:36:05 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Sun 2023-01-15 09:35:53 UTC, end at Sun 2023-01-15 09:39:41 UTC. –
Jan 15 09:36:08 umbrel systemd[1]: Starting External Storage SDcard Updater…
Jan 15 09:36:08 umbrel external storage updater[766]: Checking if SD card Umbrel is newer than external storage…
Jan 15 09:36:08 umbrel external storage updater[766]: No, SD version is not newer, exiting.
Jan 15 09:36:08 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
Umbrel logs
Tor Proxy logs
==== Result ====
Did anyone encounter this bp?
I solved it by using this post : (https://stackoverflow.com/questions/43537790/docker-fails-to-start-due-to-volume-store-metadata-database-timeout) and then this one : https://www.reddit.com/r/getumbrel/comments/phh5tn/stuck_on_starting_umbrel_screen/
Well, I see Lexar SS D NM610PRO 2TB . But I could not find that model in Lexar site.
And I doubt Raspi can suport amperage demand of any 2TB SSD.
Try reinstal with a 1GB ssd. Delete all partitions on ssd before new instal.
