Just built my node, but when I go to the umbrel website, it just spins and says connecting (FireFox is also showing it as not secure). I’m on Windows 10. I went into my router and changed the IP to static that it connects to, but when I run arp -a in CMD, it still is showing dynamic…
Anyways, here’s my logs:
0.4.17
Flashed OS version
v0.4.17
Raspberry Pi Model
Revision : d03115
Serial : 1000000027974429
Firmware
Dec 1 2021 15:01:54
Copyright (c) 2012 Broadcom
Temperature
temp=42.3’C
Throttling
throttled=0x0
Mem: 7.8G 158M 7.4G 8.0M 232M 7.5G
Swap: 4.1G 0B 4.1G
total: 2.0%
system: 2%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
tail: cannot open ‘/home/umbrel/umbrel/scripts/../logs/memory-monitor.log’ for reading: No such file or directory
/dev/root 29G 3.1G 25G 12% /
/dev/sda1 916G 5.6G 864G 1% /home/umbrel/umbrel
Startup service logs
May 08 20:57:04 umbrel umbrel startup[32436]: ========= UMBREL (mainnet) ===========
May 08 20:57:04 umbrel umbrel startup[32436]: ======================================
May 08 20:57:08 umbrel umbrel startup[32436]: Skipping lnd.conf update to preserve user changes…
May 08 20:57:08 umbrel umbrel startup[32436]: Generating hidden services…
May 08 20:57:10 umbrel umbrel startup[32436]: Starting tor …
May 08 20:57:10 umbrel umbrel startup[32436]: Starting tor … error
May 08 20:57:10 umbrel umbrel startup[32436]: ERROR: for tor Cannot start service tor_proxy: network a668257901c63f159c68ac563b096af0002df6d998a4693468d62cae5a75a1d7 not found
May 08 20:57:10 umbrel umbrel startup[32436]: ERROR: for tor_proxy Cannot start service tor_proxy: network a668257901c63f159c68ac563b096af0002df6d998a4693468d62cae5a75a1d7 not found
May 08 20:57:10 umbrel umbrel startup[32436]: Encountered errors while bringing up the project.
May 08 20:57:10 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
May 08 20:57:10 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
May 08 20:57:10 umbrel systemd[1]: Failed to start Umbrel Startup Service.
May 08 20:57:20 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
May 08 20:57:20 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 25.
May 08 20:57:20 umbrel systemd[1]: Stopped Umbrel Startup Service.
May 08 20:57:20 umbrel systemd[1]: Starting Umbrel Startup Service…
May 08 20:57:20 umbrel umbrel startup[1324]: ======================================
May 08 20:57:20 umbrel umbrel startup[1324]: ============ CONFIGURING =============
May 08 20:57:20 umbrel umbrel startup[1324]: ========= UMBREL (mainnet) ===========
May 08 20:57:25 umbrel umbrel startup[1324]: Skipping lnd.conf update to preserve user changes…
May 08 20:57:25 umbrel umbrel startup[1324]: Generating hidden services…
May 08 20:57:26 umbrel umbrel startup[1324]: Starting tor …
May 08 20:57:26 umbrel umbrel startup[1324]: Starting tor … error
May 08 20:57:26 umbrel umbrel startup[1324]: ERROR: for tor Cannot start service tor_proxy: network a668257901c63f159c68ac563b096af0002df6d998a4693468d62cae5a75a1d7 not found
May 08 20:57:26 umbrel umbrel startup[1324]: ERROR: for tor_proxy Cannot start service tor_proxy: network a668257901c63f159c68ac563b096af0002df6d998a4693468d62cae5a75a1d7 not found
May 08 20:57:26 umbrel umbrel startup[1324]: Encountered errors while bringing up the project.
May 08 20:57:26 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
May 08 20:57:26 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
May 08 20:57:26 umbrel systemd[1]: Failed to start Umbrel Startup Service.
External storage service logs
– Logs begin at Sun 2022-05-08 19:36:44 UTC, end at Sun 2022-05-08 20:57:26 UTC. –
May 08 19:36:48 umbrel systemd[1]: Starting External Storage Mounter…
May 08 19:36:48 umbrel external storage mounter[506]: Running external storage mount script…
May 08 19:36:49 umbrel external storage mounter[506]: Found device “ATA Samsung SSD 870”
May 08 19:36:49 umbrel external storage mounter[506]: Blacklisting USB device IDs against UAS driver…
May 08 19:36:49 umbrel external storage mounter[506]: Rebinding USB drivers…
May 08 19:36:49 umbrel external storage mounter[506]: Checking USB devices are back…
May 08 19:36:49 umbrel external storage mounter[506]: Waiting for USB devices…
May 08 19:36:50 umbrel external storage mounter[506]: Waiting for USB devices…
May 08 19:36:51 umbrel external storage mounter[506]: Waiting for USB devices…
May 08 19:36:52 umbrel external storage mounter[506]: Waiting for USB devices…
May 08 19:36:53 umbrel external storage mounter[506]: Checking if the device is ext4…
May 08 19:36:53 umbrel external storage mounter[506]: Yes, it is ext4
May 08 19:36:53 umbrel external storage mounter[506]: Checking if device contains an Umbrel install…
May 08 19:36:53 umbrel external storage mounter[506]: Yes, it contains an Umbrel install
May 08 19:36:53 umbrel external storage mounter[506]: Bind mounting external storage over local Umbrel installation…
May 08 19:36:53 umbrel external storage mounter[506]: Bind mounting external storage over local Docker data dir…
May 08 19:36:53 umbrel external storage mounter[506]: Bind mounting external storage to /swap
May 08 19:36:53 umbrel external storage mounter[506]: Bind mounting SD card root at /sd-card…
May 08 19:36:53 umbrel external storage mounter[506]: Checking Umbrel root is now on external storage…
May 08 19:36:54 umbrel external storage mounter[506]: Checking /var/lib/docker is now on external storage…
May 08 19:36:54 umbrel external storage mounter[506]: Checking /swap is now on external storage…
May 08 19:36:54 umbrel external storage mounter[506]: Setting up swapfile
May 08 19:36:54 umbrel external storage mounter[506]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
May 08 19:36:54 umbrel external storage mounter[506]: no label, UUID=61f63d71-f005-43af-b3ae-9bc84099f3cd
May 08 19:36:54 umbrel external storage mounter[506]: Checking SD Card root is bind mounted at /sd-root…
May 08 19:36:54 umbrel external storage mounter[506]: Starting external drive mount monitor…
May 08 19:36:54 umbrel external storage mounter[506]: Mount script completed successfully!
May 08 19:36:54 umbrel systemd[1]: Started External Storage Mounter.
May 08 19:37:01 umbrel systemd[1]: Starting External Storage SDcard Updater…
May 08 19:37:01 umbrel external storage updater[928]: Checking if SD card Umbrel is newer than external storage…
May 08 19:37:01 umbrel external storage updater[928]: No, SD version is not newer, exiting.
May 08 19:37:01 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Attaching to
Bitcoin Core logs
Attaching to
LND logs
Attaching to
electrs logs
Attaching to
Tor logs
Attaching to tor
tor | May 07 22:43:57.909 [notice] Opened Control listener connection (ready) on 10.21.21.11:29051
tor | May 07 22:43:57.000 [notice] Bootstrapped 0% (starting): Starting
tor | May 07 22:43:57.000 [notice] Starting with guard context “default”
tor | May 07 22:43:58.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor | May 07 22:43:59.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor | May 07 22:43:59.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor | May 07 22:43:59.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor | May 07 22:43:59.000 [notice] Bootstrapped 20% (onehop_create): Establishing an encrypted directory connection
tor | May 07 22:43:59.000 [notice] Bootstrapped 25% (requesting_status): Asking for networkstatus consensus
tor | May 07 22:43:59.000 [notice] Catching signal TERM, exiting cleanly.
==== Result ====
umbrel@umbrel:~ $
