I have a RPI 4B, 8GB, 2TB SSD. Running umbrelOS 1.4.2
I have a cooling fan and temp is 37 deg C. I would like to overclock it slightly. I had no problem doing it before by editing /boot/config.txt
When I try to edit the config.txt file, it looks like its read only without ability to save.
Can we overclock RPI4 (1.4.2)?
Is this the config file: /boot/config.txt?
How can enable editing/save on the file?
I fully understand the risk to node stability when overclocked.
Thanks
