Raspi-config not working since Umbrel 1.0
sudo raspi-config is not working anymore. Also after installing the service I get the following error:
sed: couldn't open temporary file /boot/seduu9TL6: Read-only file system
sed: couldn't open temporary file /boot/sedWPoT0Y: Read-only file system
Does anyone know how to configure the cpu fan settings in Umbrel 1.0?
I want to activate the fan only if the cpu temperature is higher than 60°
I’m finding my RPi5 is running at high 40’s to 51c with out the fan running at all.
Hm. this does not really help. I’m want to know where i can configure the cpu fan.
I have exactly the same problem. Fan is now on all the time.
Wondering if anyone has figured this out. raspi-config used to work great for fan control. The fan would activate only once in a while. Now with Umbrel 1+ the fan is on all the time. I installed raspi-config, and I could configure the fan to activate at 60C but it wouldn’t take. The fan is still on all the time.
Any other ideas? Thanks!
