Onchain and Lightening wallets constantly Synchronising
Hi over the last couple of days my Umbrel node Build 0.4.8 constantly shows syncronising both the Bitcoin and Lightning wallet. it has been working well for over 8 months Bitcoin Core is fully syncronised and validateing new blocks. I cannot see my onchain balance or Lightning balance or channels can anyone provide any assistance. I have not experienced any power outage and as a first point of troubleshooting I resarted the node but it made no difference.
  1. Read troubleshooting manual
  2. Update to v 0.4.10 manually or reflash the mSD card with latest version
  3. review your lnd.conf file if is not containing some wrong line.
  4. wait patiently until electrs is rebuilding the index blocks
Thankyou I have successfully "manually"updated my Umbrel node to 0.4.10 using the troubleshooting guide. My lnd.conf file has not been changed for over a month and node has successfully rebooted since changing. Unfortunately my Wallets and Channels are still not displaying even though Bitcoin Core is fully synchronised and validating blocks. I have checked the electrs log and there are many warnings (see extract below).
Should I run the sudo systemctl stop umbrel-startup && sudo rm -rf ~/umbrel/electrs/!(electrs.toml) && sudo systemctl start umbrel-startup Command to rebuild/repair the electrs DB
2022-01-13T22:04:21.317Z INFO electrs::chain] chain updated: tip=000000000000000000045c35ce7c631038b8afe39acec6c4b9970bd46ed74278, height=718541
electrs | [2022-01-13T22:05:52.470Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [2, 175, 161, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 61, 244, 144, 186, 32, 141, 225, 159, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 69, 117, 225, 77, 32, 141] }
electrs | [2022-01-13T22:08:38.841Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 122, 160, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 204, 112, 160, 191, 32, 141] }
electrs | [2022-01-13T22:10:06.290Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 219, 160, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 31, 30, 46, 64, 32, 141] }
electrs | [2022-01-13T22:15:06.861Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 239, 161, 224, 97, 13, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 5, 196, 240, 193, 32, 141] }
electrs | [2022-01-13T22:17:14.470Z INFO electrs::index] indexing 1 blocks: [718542…718542]
electrs | [2022-01-13T22:17:14.635Z INFO electrs::chain] chain updated: tip=00000000000000000000bbc672d7a1705ab9bd7f654ccd1f4c4803415c1dc7db, height=718542
electrs | [2022-01-13T22:20:07.673Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [3, 219, 164, 224, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 3, 35, 138, 214, 32, 141, 208, 163, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 77, 1, 165, 78, 32, 141, 60, 163, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 13, 40, 18, 97, 32, 141] }
electrs | [2022-01-13T22:20:52.104Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 114, 163, 224, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 34, 90, 157, 209, 32, 141] }
electrs | [2022-01-13T22:21:40.688Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 134, 164, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 163, 172, 81, 70, 32, 141] }
electrs | [2022-01-13T22:26:14.674Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 243, 164, 224, 97, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 185, 250, 207, 226, 32, 141] }
electrs | [2022-01-13T22:28:27.198Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 25, 166, 224, 97, 13, 0, 0, 0, 0, 0, 0, 0, 32, 1, 0, 0, 157, 56, 106, 184, 48, 142, 246, 52, 167, 156, 190, 73, 32, 151] }
electrs | [2022-01-13T22:30:30.354Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 13, 166, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 95, 29, 164, 57, 32, 141] }
electrs | [2022-01-13T22:37:26.462Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [1, 76, 168, 224, 97, 8, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 194, 99, 104, 148, 32, 141] }
electrs | [2022-01-13T22:37:50.418Z INFO electrs::index] indexing 1 blocks: [718543…718543]
electrs | [2022-01-13T22:37:50.600Z INFO electrs::chain] chain updated: tip=00000000000000000007c535d03b4d6a11dc13979b1fe8addb43a063d5473cf1, height=718543
electrs | [2022-01-13T22:38:29.120Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [2, 82, 169, 224, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 15, 185, 151, 207, 32, 141, 220, 167, 224, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 70, 91, 250, 149, 32, 141] }
electrs | [2022-01-13T22:40:41.263Z WARN electrs::p2p] unexpected message: Unknown { command: CommandString(“addr”), payload: [2, 245, 167, 224, 97, 13, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 146, 241, 54, 168, 32, 141, 141, 168, 224, 97, 9, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 255, 255, 193, 198, 68, 185, 32, 141] }
No, just wait patiently more time.
Hi I waited for 100hrs and decided to upgrade to version 0.10.11 now my electra logs look cleaner although I still my onchain wallet and lightning wallet are still showing synchronising.
electrs | [2022-01-18T17:45:26.846Z INFO electrs::chain] chain updated: tip=00000000000000000003a4dd08cb8f2fd75053377353c9616d4a59f3bb154d3b, height=719309
electrs | [2022-01-18T17:45:36.087Z INFO electrs::index] indexing 1 blocks: [719310…719310]
electrs | [2022-01-18T17:45:38.333Z INFO electrs::chain] chain updated: tip=0000000000000000000b884f76815a8c1766e8a478a1ff0aeec21402e381ba38, height=719310
electrs | [2022-01-18T17:45:41.510Z INFO electrs::index] indexing 1 blocks: [719311…719311]
electrs | [2022-01-18T17:45:41.666Z INFO electrs::chain] chain updated: tip=00000000000000000004241e87b16e3d81c81179e832a3ff11e65803ddf21101, height=719311
electrs | [2022-01-18T17:57:03.421Z INFO electrs::index] indexing 1 blocks: [719312…719312]
electrs | [2022-01-18T17:57:03.602Z INFO electrs::chain] chain updated: tip=00000000000000000000e15060db1e7bc1dcc07ea2ea718b6c8ac558b4f21c8c, height=719312
electrs | [2022-01-18T17:59:33.022Z INFO electrs::index] indexing 1 blocks: [719313…719313]
electrs | [2022-01-18T17:59:33.142Z INFO electrs::chain] chain updated: tip=000000000000000000065ec2a7cf7a89e2bc51d880d7ecf07c749a3062d2a656, height=719313
electrs | [2022-01-18T18:00:58.205Z INFO electrs::index] indexing 1 blocks: [719314…719314]
electrs | [2022-01-18T18:00:58.395Z INFO electrs::chain] chain updated: tip=00000000000000000007177d1404d48cfdf85802faf6958d27e28e9446725c37, height=719314
electrs | [2022-01-18T18:40:21.899Z INFO electrs::index] indexing 1 blocks: [719315…719315]
electrs | [2022-01-18T18:40:22.038Z INFO electrs::chain] chain updated: tip=00000000000000000009d4014a74a24610c613306df36c5e0e18256b1a3466cf, height=719315
electrs | [2022-01-18T18:45:59.322Z INFO electrs::index] indexing 1 blocks: [719316…719316]
electrs | [2022-01-18T18:45:59.597Z INFO electrs::chain] chain updated: tip=00000000000000000004ecee293e5d24b80237fcbbedc800271a1eac76508772, height=719316
electrs | [2022-01-18T18:56:28.110Z INFO electrs::index] indexing 1 blocks: [719317…719317]
electrs | [2022-01-18T18:56:28.297Z INFO electrs::chain] chain updated: tip=000000000000000000046c38b1f01cf7f13a0dd4a2fe1ba099cc72e1697c2cfd, height=719317
electrs | [2022-01-18T19:00:22.638Z INFO electrs::index] indexing 1 blocks: [719318…719318]
electrs | [2022-01-18T19:00:22.763Z INFO electrs::chain] chain updated: tip=000000000000000000004128a67d2012ee4252d92daecddaae6a8d87799b7f6a, height=719318
electrs | [2022-01-18T19:01:25.071Z INFO electrs::index] indexing 1 blocks: [719319…719319]
electrs | [2022-01-18T19:01:25.186Z INFO electrs::chain] chain updated: tip=00000000000000000008d95e2aab5433fd76c8aa5580ee8586082072d3871018, height=719319
electrs | [2022-01-18T19:12:44.849Z INFO electrs::index] indexing 1 blocks: [719320…719320]
electrs | [2022-01-18T19:12:45.098Z INFO electrs::chain] chain updated: tip=00000000000000000006b94f47861e4bf9966715cb89009b81ec9640b8e18548, height=719320
electrs | [2022-01-18T19:16:28.336Z INFO electrs::index] indexing 1 blocks: [719321…719321]
electrs | [2022-01-18T19:16:28.602Z INFO electrs::chain] chain updated: tip=00000000000000000008bd0c24da8ce0218284cfa470719d615cf5bda4533907, height=719321
electrs | [2022-01-18T19:18:24.772Z INFO electrs::index] indexing 1 blocks: [719322…719322]
electrs | [2022-01-18T19:18:24.938Z INFO electrs::chain] chain updated: tip=000000000000000000087a3004c912cd9c6bbc2a59f0da79b89578de60869b2a, height=719322
electrs | [2022-01-18T19:25:58.246Z INFO electrs::index] indexing 1 blocks: [719323…719323]
electrs | [2022-01-18T19:25:58.416Z INFO electrs::chain] chain updated: tip=00000000000000000005c3fd8cc498cbf9c70ea81d05514c749387870908bc8c, height=719323
electrs | [2022-01-18T19:27:58.975Z INFO electrs::index] indexing 1 blocks: [719324…719324]
electrs | [2022-01-18T19:27:59.147Z INFO electrs::chain] chain updated: tip=0000000000000000000832bf9d992dec17a0c0af3ce997d717574e024e318e91, height=719324
electrs | [2022-01-18T19:39:53.127Z INFO electrs::index] indexing 1 blocks: [719325…719325]
electrs | [2022-01-18T19:39:53.288Z INFO electrs::chain] chain updated: tip=000000000000000000021ea7ed465a0c90e3210bdfe1d807267f9e06dacc072e, height=719325
electrs | [2022-01-18T20:04:18.461Z INFO electrs::index] indexing 1 blocks: [719326…719326]
electrs | [2022-01-18T20:04:25.669Z INFO electrs::chain] chain updated: tip=00000000000000000007cf8892252578c7bbbaee765f26ff3040d1358579c0b5, height=719326
electrs | [2022-01-18T20:09:55.028Z INFO electrs::index] indexing 1 blocks: [719327…719327]
electrs | [2022-01-18T20:09:55.239Z INFO electrs::chain] chain updated: tip=00000000000000000003b94c02b5b8d8c494e0cdb742aa08bf4cf2d6407320e8, height=719327
electrs | [2022-01-18T20:27:03.590Z INFO electrs::index] indexing 1 blocks: [719328…719328]
electrs | [2022-01-18T20:27:03.800Z INFO electrs::chain] chain updated: tip=0000000000000000000762f99617f8db176d5e70f5c60c379cbbc4b947787e4b, height=719328
electrs | [2022-01-18T20:34:19.363Z INFO electrs::index] indexing 1 blocks: [719329…719329]
electrs | [2022-01-18T20:34:19.490Z INFO electrs::chain] chain updated: tip=0000000000000000000880d32fd1321a69593493cd2b18d654350741bfbd6a55, height=719329
electrs | [2022-01-18T20:37:00.306Z INFO electrs::index] indexing 1 blocks: [719330…719330]
electrs | [2022-01-18T20:37:00.501Z INFO electrs::chain] chain updated: tip=0000000000000000000a906937f80da60edfad55144bbe08f4885ee8436aedec, height=719330
electrs | [2022-01-18T20:48:12.387Z INFO electrs::index] indexing 1 blocks: [719331…719331]
electrs | [2022-01-18T20:48:12.536Z INFO electrs::chain] chain updated: tip=00000000000000000008576ac35871fd0a7a07088036ab9a2a757a43b83e8838, height=719331
electrs | [2022-01-18T20:49:35.474Z INFO electrs::index] indexing 1 blocks: [719332…719332]
electrs | [2022-01-18T20:49:38.766Z INFO electrs::chain] chain updated: tip=000000000000000000015c4527b1eaaa4bb1b635f97644202c087dc08afd45af, height=719332
electrs | [2022-01-18T20:54:39.951Z INFO electrs::index] indexing 1 blocks: [719333…719333]
electrs | [2022-01-18T20:54:40.155Z INFO electrs::chain] chain updated: tip=00000000000000000009064fad6be7a1e924e418d48ba68ccb2b7b685d275ff2, height=719333
electrs | [2022-01-18T21:03:02.922Z INFO electrs::index] indexing 1 blocks: [719334…719334]
electrs | [2022-01-18T21:03:03.070Z INFO electrs::chain] chain updated: tip=0000000000000000000863d51181ca228237fb6bb38805b1f59de6393f236431, height=719334
electrs | [2022-01-18T21:08:30.099Z INFO electrs::index] indexing 1 blocks: [719335…719335]
electrs | [2022-01-18T21:08:30.321Z INFO electrs::chain] chain updated: tip=00000000000000000009087f9e91f6cdf2f430399743e58b86f4b20839e494df, height=719335
electrs | [2022-01-18T21:24:36.248Z INFO electrs::index] indexing 1 blocks: [719336…719336]
electrs | [2022-01-18T21:24:36.445Z INFO electrs::chain] chain updated: tip=00000000000000000001539648642f49f7660d02e986110920fcbf16f604baef, height=719336
electrs | [2022-01-18T21:35:02.060Z INFO electrs::index] indexing 1 blocks: [719337…719337]
electrs | [2022-01-18T21:35:02.311Z INFO electrs::chain] chain updated: tip=0000000000000000000adbea7932a956b7c35282cd6f594af20eda44c876d67d, height=719337
electrs | [2022-01-18T21:44:41.653Z INFO electrs::index] indexing 1 blocks: [719338…719338]
electrs | [2022-01-18T21:44:41.747Z INFO electrs::chain] chain updated: tip=000000000000000000024b08d13775951b1b5f6436f43347b95b3e3dd3cbfa90, height=719338
electrs | [2022-01-18T21:47:44.790Z INFO electrs::index] indexing 1 blocks: [719339…719339]
electrs | [2022-01-18T21:47:44.844Z INFO electrs::chain] chain updated: tip=000000000000000000055bf051dbad34b6cf70a27bb7964abe8ab88c9f5b0bba, height=719339
electrs | [2022-01-18T22:01:11.989Z INFO electrs::index] indexing 1 blocks: [719340…719340]
electrs | [2022-01-18T22:01:12.119Z INFO electrs::chain] chain updated: tip=00000000000000000004411f3c091fe29e5e350a35119e4da674fffbae0a4601, height=719340
electrs | [2022-01-18T22:21:00.025Z INFO electrs::index] indexing 1 blocks: [719341…719341]
electrs | [2022-01-18T22:21:00.152Z INFO electrs::chain] chain updated: tip=0000000000000000000112f7ed7d02ae572597a1b08bd58a498966b6b4532fce, height=719341
electrs | [2022-01-18T22:30:59.207Z INFO electrs::index] indexing 1 blocks: [719342…719342]
electrs | [2022-01-18T22:30:59.325Z INFO electrs::chain] chain updated: tip=0000000000000000000a9b6801aee8e58b9ec4247f36ef35f3ab54b0fb38d8d0, height=719342
electrs | [2022-01-18T22:33:59.916Z INFO electrs::index] indexing 1 blocks: [719343…719343]
electrs | [2022-01-18T22:34:00.044Z INFO electrs::chain] chain updated: tip=0000000000000000000798289b2fbbf5898ef562408df349c94e2093bfb54e44, height=719343
electrs | [2022-01-18T22:45:25.244Z INFO electrs::index] indexing 1 blocks: [719344…719344]
electrs | [2022-01-18T22:45:25.467Z INFO electrs::chain] chain updated: tip=00000000000000000009f0dfc33ff387cf0dad1af45987c157cfe255e52849a6, height=719344
Hi my Lightning and Bitcoin wallets are still synchronising. the Electrs logs look like they have reindexed as does bitcoin core (Fully Synchronised) I have checked the lnd.config file that looks OK I do see the following in the LND log
Attaching to lnd
lnd | created by go.etcd.io/bbolt.(*DB).freepages
lnd | go.etcd.io/bbolt@v1.3.6/db.go:1054 +0x134
lnd | 2022-01-24 07:03:57.518 [INF] LTND: Version: 0.14.1-beta commit=v0.14.1-beta, build=production, logging=default, debuglevel=info
lnd | 2022-01-24 07:03:57.518 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2022-01-24 07:03:57.532 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd | 2022-01-24 07:03:57.535 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd | 2022-01-24 07:03:57.535 [INF] LTND: Opening the main database, this might take a few minutes…
lnd | 2022-01-24 07:03:57.535 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2022-01-24 07:03:57.604 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lnd | panic: freepages: failed to get all reachable pages (page 71155: multiple references)
lnd |
lnd | goroutine 185 [running]:
lnd | go.etcd.io/bbolt.(*DB).freepages.func2(0x4000276960)
lnd | go.etcd.io/bbolt@v1.3.6/db.go:1056 +0xc4
lnd | 2022-01-24 07:05:03.851 [INF] LTND: Version: 0.14.1-beta commit=v0.14.1-beta, build=production, logging=default, debuglevel=info
lnd | 2022-01-24 07:05:03.851 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2022-01-24 07:05:03.854 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd | 2022-01-24 07:05:03.857 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd | 2022-01-24 07:05:03.858 [INF] LTND: Opening the main database, this might take a few minutes…
lnd | 2022-01-24 07:05:03.858 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2022-01-24 07:05:04.016 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lnd |
lnd | goroutine 190 [running]:
lnd | go.etcd.io/bbolt.(*DB).freepages.func2(0x40000ed4a0)
your assistance is greatly appreciated.
Question: did you edit your lnd.conf file with adding a watchtower?
Sometimes WT line/connection is hanging LND to start.
Try removing WT line in lnd.conf and restart your node
There is no WT references in the lnd.config
Login to your node with an SSH client / Power terminal via
ssh -t umbrel@umbrel.local
Make a backup of your current lnd.conf
cp ~/umbrel/lnd/lnd.conf ~/umbrel/lnd/lnd.bak
Delete your current lnd.conf, re-configure Umbrel and restart the node
rm ~/umbrel/lnd/lnd.conf && ~/umbrel/scripts/configure && sudo reboot
After restart, your LND will take a few minutes to catch up again.
Go into the Umbrel Dashboard > Settings > Debug again and validate the wallet is unlocked this time.
Thanx @DarthCoin the electrs indexing is up-to-date. the wallets are still not Synchronising
Umbrel Logs
I see, all seems to be fine, but something is missing there.
Can you run
docker-compose logs lnd
and see if there are more aditional errors there?
Also
docker-compose logs bitcoin
can help to see if the wallet is locked or something strange.
I know is really frustrating this phase when is not showing the wallets.
I appreciate any help you can give @DarthCoin as my channel partners are asking about my node being offline. I needed to run the LND command with the --tail=300 option as the log was too long to send via 0bin and they were the same logs displayed over and over.
LND Log
Bitcoin Log
It doesn’t seems to have any error apart from that
in lnd log.
Did you tried to login to umbrel dashboard? Once you enter, is unlocking the lnd wallet.
Just open the dashboard.
Are you sure you have a “virgin” lnd.conf file?
I don’t know man, have a bit more patience, maybe is still building the lnd database, but I see the bitcoin sync all ok.
When I log into the dashboard I see the following screens. The Wallets [Bitcoin and Lightning] are constantly showing Synchronising and Bitcoin Core shows Synchronised
I reset the lnd.config file as per your instructions and did not modify it so it is a new copy
I can wait longer if you think that will help. How many days do you think is reasonable?
I can also confirm that the Node can also display the seed phrase and they are the same words that I wrote down when I setup the node.
Delete this.
If you reset it, is fine, just wait few hours and let’s see how is going.
Still same problem with the Wallet and Lightning wallets constantly synchronising I do see Unable to get wallet balance, failed to connect to all addresses in the logs any more thoughts?
middleware | umbrel-middleware
middleware | Unable to get lnd information, failed to connect to all addresses
middleware | /v1/lnd/info/sync
middleware | LndError: Unable to get lnd information
middleware | at /app/services/lnd.js:69:18
middleware | at Object.onReceiveStatus (/app/node_modules/grpc/src/client_interceptors.js:1210:9)
middleware | at InterceptingListener._callNext (/app/node_modules/grpc/src/client_interceptors.js:568:42)
middleware | at InterceptingListener.onReceiveStatus (/app/node_modules/grpc/src/client_interceptors.js:618:8)
middleware | at callback (/app/node_modules/grpc/src/client_interceptors.js:847:24)
middleware | ::ffff:10.21.21.2 - - [Fri, 28 Jan 2022 05:47:05 GMT] “GET /v1/lnd/info/sync HTTP/1.0” 500 67 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.54 Safari/537.36”
middleware |
middleware | Unable to get wallet balance, failed to connect to all addresses
middleware | /v1/lnd/wallet/btc
middleware | LndError: Unable to get wallet balance
middleware | ::ffff:10.21.21.2 - - [Fri, 28 Jan 2022 05:47:05 GMT] “GET /v1/lnd/wallet/btc HTTP/1.0” 500 66 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.54 Safari/537.36”
middleware |
@DarthCoin what is your opinion of running sed -i “s/[Application Options]/[Application Options]\nreset-wallet-transactions=true/g;” ~/umbrel/lnd/lnd.conf && sudo reboot to rescan the wallets UTXO’s will this cause more problems troubleshooting the issue?
You post only the middleware logs. Middleware is just a web interface, it doesn’t affect your node to run properly.
The problem is not there.
Look closer into your logs, in bitcoin logs, lnd logs, electrs logs
Is this of interest in the LND log
lnd | https://protect-au.mimecast.com/s/oElUCL7EAnu84WGCmzN95?domain=go.etcd.io +0xc4
lnd | created by https://protect-au.mimecast.com/s/paeJCMwG7oUmWrwIQF7QX?domain=go.etcd.io
lnd | https://protect-au.mimecast.com/s/VkUgCNLJ7pcyXWOF0QHjZ?domain=go.etcd.io +0x134
lnd | 2022-01-31 01:32:42.062 [INF] LTND: Version: 0.14.1-beta commit=v0.14.1-beta, build=production, logging=default, debuglevel=info
lnd | 2022-01-31 01:32:42.063 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2022-01-31 01:32:42.067 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd | 2022-01-31 01:32:42.146 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd | 2022-01-31 01:32:42.146 [INF] LTND: Opening the main database, this might take a few minutes…
lnd | 2022-01-31 01:32:42.146 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2022-01-31 01:32:42.397 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
please start the full debug logs and paste them on pastebin or whatever other bin service
