Dump the iShit and buy a decent android device and install CalyxOS or GrapheneOS,
anyway, to use older versions of BW, you need to use it together with Orbot Tor VPN to access your node. But for iShit devices that option is NOT available and will never be. So see advice no. 1
Not very helpful.
I already did “dump the iShit” for an Android which I run everyday.
What I wanted was a third device to setup a multisig with. Seemed to me to be a good use for a backup phone.
Anyone else got some useful advice to connect an old version of Blue Wallet to my LNDHub?
