I am trying to use in NVME Drive with my raspberry pie for and Umbrel Bitcoin node software. However the nvme drive and enclosure combo are not being recognized as expected. Need help badly. I already replace both products and have new ones and they don’t work either. This is what I purchased:
NVME Drive:
ENCLOSURE:
Appreciated. Discouraged at the moment. Just want my node running with this NVME!!
Did you test them in a PC or a laptop usb3 port? If they work, then problem is power shortage in Raspi system.
The more the speed, the more peak amps, if that excess current not available corruption and instability will happen in ssd.
So you’re suggesting I just buy new hardware to fix my problem because you don’t like the raspberry PIs? No thanks
Also, not really the solution I was looking for, but new #&@$.
Can you verify that a new cable fixed this for you? I’m having trouble with my NVMe on a fresh install. tried several cables and even a USB-C to USB-C with a USB-A adapter. I get different errors depending on the cable/combination but its either; Error: System service failed - or error finding external drive, again depending on the cable/combo used.
I went with: Drive
See another post about the Realtek RTL9210 not being supported - this is my case.
So…not sure if I should look at new case?
NVMe maybe overkill anyway? USB3.0 Bus able to support? Was just hoping for fast load of the whole BTC chain and lower power consumption.
Been a long day trouble shooting.
Here is a copy of the log in case anyone’s interested: https://0bin.net/paste/qEJmW8RJ#q977puVoFFqkW99vQeNJAZlZ6fWCH2An0rZ3fCLzi7b
External storage system not working. Test storage system, change USB cables and cases to find the problem.
It is easy: with a PC, format the disk any format type you like, write to it a large file (+ 1GB), then do a copy of that large file to the same disk. Observe copy behaviour and speed. In a health system, speed should be steady, and in the range 100 - 160MB/s.
