I am trying to use the “Sync Public Relays” feature and encountering this error message:
EACCES: permission denied, open ‘./data/store.json’
I don’t see this file in the ~/umbrel/app-data/nostr-relay/data directory.
Suggestions on how to fix?
Update: I have solved this issue. It appears the problem was that I was using a custom user name, not “umbrel”, so the user didn’t have write permissions. I was able to fix it using this command:
sudo chown -R username:username ~/umbrel/app-data/nostr-relay/data
