Node stopped working
Hi guys,
my node has stopped working, all the apps will not run. iv tried reflasing, no joy and now i cant ssh into.
bitcoin core logs below.
please help
Command failed with exit code 1: /opt/umbreld/source/modules/apps/legacy-compat/app-script logs bitcoin
time=“2025-06-30T07:34:39Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-06-30T07:34:39Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.tor.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-06-30T07:34:39Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
time=“2025-06-30T07:34:39Z” level=warning msg=“networks.default: external.name is deprecated. Please set name and external: true”
time=“2025-06-30T07:34:39Z” level=warning msg=“/home/umbrel/umbrel/app-data/bitcoin/docker-compose.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
I see, what’s the hardware configuration?
