I use my Umbrel just for Bitcoin basically.
For some reason, the Bitcoin Node stopped working.
I will add some logs to see if somebody can help me
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_i2pd_daemon_1, bitcoin_app_proxy_1, bitcoin_tor_server_1, bitcoin_tor_1
app_proxy_1 | Validating token: 854a9dff2378 ...
bitcoind_1 | 2024-12-07T00:07:32Z * Using 53.4 MiB for transaction index database
bitcoind_1 | 2024-12-07T00:07:32Z * Using 46.7 MiB for basic block filter index database
bitcoind_1 | 2024-12-07T00:07:32Z * Using 8.0 MiB for chain state database
bitcoind_1 | 2024-12-07T00:07:32Z * Using 318.9 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
bitcoind_1 | 2024-12-07T00:07:32Z [error] Failed to initialize ChainstateManager: AutoFile::read: end of file: iostream error
bitcoind_1 | 2024-12-07T00:07:32Z Shutdown: In progress...
bitcoind_1 | Error: Failed to initialize ChainstateManager: AutoFile::read: end of file: iostream error
bitcoind_1 | 2024-12-07T00:07:32Z scheduler thread exit
bitcoind_1 | 2024-12-07T00:07:32Z Flushed fee estimates to fee_estimates.dat.
bitcoind_1 | 2024-12-07T00:07:32Z Shutdown: done
i2pd_daemon_1 | 23:59:04@760/error - Tunnels: Can't select next hop for nIOzMXZ-N9PDr1TanGQ1L2RU9nAbzmJwshac2DNTkNE=
i2pd_daemon_1 | 23:59:04@760/error - Tunnels: Can't create inbound tunnel, no peers available
i2pd_daemon_1 | 00:00:13@604/error - SSU2: RelayIntro unknown router to introduce
i2pd_daemon_1 | 00:01:23@805/error - Garlic: Can't handle ECIES-X25519-AEAD-Ratchet message
i2pd_daemon_1 | 00:01:34@760/error - Tunnels: Can't select next hop for NA~k5oM21ZQBTI3TlsHX4CfNKKxqL6tqN9ORCJF5HTc=
i2pd_daemon_1 | 00:01:34@760/error - Tunnels: Can't create inbound tunnel, no peers available
i2pd_daemon_1 | 00:01:49@760/error - Tunnels: Can't select next hop for Q~kwklRdkMX8O3UHMv8sdPfx6TlEdD~8BRiZXeAqWjg=
i2pd_daemon_1 | 00:01:49@760/error - Tunnels: Can't create inbound tunnel, no peers available
i2pd_daemon_1 | 00:06:54@760/error - Tunnels: Can't select next hop for GFnJlRPOYibX19lvvspqTCjHqnDh2WPNZqXgOGreQLs=
i2pd_daemon_1 | 00:06:54@760/error - Tunnels: Can't create inbound tunnel, no peers available
tor_1 | Dec 06 23:16:36.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_1 | Dec 06 23:16:37.000 [notice] Bootstrapped 63% (loading_descriptors): Loading relay descriptors
tor_1 | Dec 06 23:16:38.000 [notice] Bootstrapped 71% (loading_descriptors): Loading relay descriptors
tor_1 | Dec 06 23:16:38.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Dec 06 23:16:39.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Dec 06 23:16:39.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Dec 06 23:16:39.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Dec 06 23:16:40.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Dec 06 23:16:40.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Dec 06 23:16:41.000 [notice] Bootstrapped 100% (done): Done
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.9 - - [Sat, 07 Dec 2024 00:08:18 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"
server_1 |
server_1 | ::ffff:10.21.0.9 - - [Sat, 07 Dec 2024 00:08:21 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"
server_1 |
server_1 | ::ffff:10.21.0.9 - - [Sat, 07 Dec 2024 00:08:24 GMT] "GET /v1/bitcoind/info/status HTTP/1.1" 304 - "-" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36"
server_1 |
And this is the log from the docker log container:
2024-12-07T00:10:35Z Using at most 125 automatic connections (1048576 file descriptors available)
2024-12-07T00:10:35Z scheduler thread start
2024-12-07T00:10:35Z Binding RPC on address 10.21.21.8 port 8332
2024-12-07T00:10:35Z Binding RPC on address 127.0.0.1 port 8332
2024-12-07T00:10:35Z Using random cookie authentication.
2024-12-07T00:10:35Z Generated RPC authentication cookie /data/.bitcoin/.cookie
2024-12-07T00:10:35Z Permissions used for cookie: rw-------
2024-12-07T00:10:35Z Using rpcauth authentication.
2024-12-07T00:10:35Z Starting HTTP server with 4 worker threads
2024-12-07T00:10:35Z Using wallet directory /data/.bitcoin
2024-12-07T00:10:35Z init message: Verifying wallet(s)…
2024-12-07T00:10:35Z Using /16 prefix for IP bucketing
2024-12-07T00:10:35Z init message: Loading P2P addresses…
2024-12-07T00:10:35Z Loaded 0 addresses from peers.dat 0ms
2024-12-07T00:10:35Z init message: Loading banlist…
2024-12-07T00:10:35Z banlist.dat ignored because it can only be read by Bitcoin Core version 22.x. Remove "/data/.bitcoin/banlist.dat" to silence this warning.
2024-12-07T00:10:35Z SetNetworkActive: true
2024-12-07T00:10:35Z Script verification uses 3 additional threads
2024-12-07T00:10:35Z Cache configuration:
2024-12-07T00:10:35Z * Using 2.0 MiB for block index database
2024-12-07T00:10:35Z * Using 53.4 MiB for transaction index database
2024-12-07T00:10:35Z * Using 46.7 MiB for basic block filter index database
2024-12-07T00:10:35Z * Using 8.0 MiB for chain state database
2024-12-07T00:10:35Z * Using 318.9 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2024-12-07T00:10:35Z [error] Failed to initialize ChainstateManager: AutoFile::read: end of file: iostream error
2024-12-07T00:10:35Z Shutdown: In progress...
2024-12-07T00:10:35Z scheduler thread exit
2024-12-07T00:10:35Z Flushed fee estimates to fee_estimates.dat.
2024-12-07T00:10:35Z Shutdown: done
2024-12-07T00:11:37Z Ignoring unknown configuration value maxtimeadjustment
2024-12-07T00:11:37Z Included configuration file umbrel-bitcoin.conf
2024-12-07T00:11:37Z Bitcoin Core version v28.0.0 (release build)
2024-12-07T00:11:37Z parameter interaction: -proxy set -> setting -upnp=0
2024-12-07T00:11:37Z parameter interaction: -proxy set -> setting -natpmp=0
2024-12-07T00:11:37Z parameter interaction: -proxy set -> setting -discover=0
2024-12-07T00:11:37Z Script verification uses 3 additional threads
2024-12-07T00:11:37Z Using the 'standard' SHA256 implementation
2024-12-07T00:11:37Z Default data directory /data/.bitcoin
2024-12-07T00:11:37Z Using data directory /data/.bitcoin
2024-12-07T00:11:37Z Config file: /data/.bitcoin/bitcoin.conf
2024-12-07T00:11:37Z Config file arg: bantime="86400"
2024-12-07T00:11:37Z Config file arg: blockfilterindex="1"
2024-12-07T00:11:37Z Config file arg: datacarriersize="83"
2024-12-07T00:11:37Z Config file arg: dbcache="429"
2024-12-07T00:11:37Z Config file arg: i2pacceptincoming="0"
2024-12-07T00:11:37Z Config file arg: i2psam="10.21.22.11:7656"
2024-12-07T00:11:37Z Config file arg: includeconf="umbrel-bitcoin.conf"
2024-12-07T00:11:37Z Config file arg: listen="1"
2024-12-07T00:11:37Z Config file arg: listenonion="0"
2024-12-07T00:11:37Z Config file arg: maxconnections="125"
2024-12-07T00:11:37Z Config file arg: maxmempool="300"
2024-12-07T00:11:37Z Config file arg: maxorphantx="100"
2024-12-07T00:11:37Z Config file arg: maxreceivebuffer="5000"
2024-12-07T00:11:37Z Config file arg: maxsendbuffer="1000"
2024-12-07T00:11:37Z Config file arg: maxuploadtarget="0"
2024-12-07T00:11:37Z Config file arg: mempoolexpiry="336"
2024-12-07T00:11:37Z Config file arg: onion="10.21.22.10:9050"
2024-12-07T00:11:37Z Config file arg: onlynet="ipv4"
2024-12-07T00:11:37Z Config file arg: onlynet="ipv6"
2024-12-07T00:11:37Z Config file arg: onlynet="onion"
2024-12-07T00:11:37Z Config file arg: onlynet="i2p"
2024-12-07T00:11:37Z Config file arg: peerblockfilters="1"
2024-12-07T00:11:37Z Config file arg: peertimeout="60"
2024-12-07T00:11:37Z Config file arg: persistmempool="1"
2024-12-07T00:11:37Z Config file arg: proxy="10.21.22.10:9050"
2024-12-07T00:11:37Z Config file arg: rpcworkqueue="128"
2024-12-07T00:11:37Z Config file arg: timeout="5000"
2024-12-07T00:11:37Z Config file arg: torcontrol="10.21.22.10:9051"
2024-12-07T00:11:37Z Config file arg: torpassword=****
2024-12-07T00:11:37Z Config file arg: txindex="1"
2024-12-07T00:11:37Z Config file arg: whitelist="10.21.0.0/16"
2024-12-07T00:11:37Z Config file arg: [main] bind="0.0.0.0:8333"
2024-12-07T00:11:37Z Config file arg: [main] bind="10.21.21.8:8334=onion"
2024-12-07T00:11:37Z Command-line arg: deprecatedrpc="create_bdb"
2024-12-07T00:11:37Z Command-line arg: deprecatedrpc="warnings"
2024-12-07T00:11:37Z Command-line arg: port="8333"
2024-12-07T00:11:37Z Command-line arg: rpcallowip="10.21.0.0/16"
2024-12-07T00:11:37Z Command-line arg: rpcallowip="127.0.0.1"
2024-12-07T00:11:37Z Command-line arg: rpcauth=****
2024-12-07T00:11:37Z Command-line arg: rpcbind="10.21.21.8"
2024-12-07T00:11:37Z Command-line arg: rpcbind="127.0.0.1"
2024-12-07T00:11:37Z Command-line arg: rpcport="8332"
2024-12-07T00:11:37Z Command-line arg: zmqpubhashblock="tcp://0.0.0.0:28334"
2024-12-07T00:11:37Z Command-line arg: zmqpubrawblock="tcp://0.0.0.0:28332"
2024-12-07T00:11:37Z Command-line arg: zmqpubrawtx="tcp://0.0.0.0:28333"
2024-12-07T00:11:37Z Command-line arg: zmqpubsequence="tcp://0.0.0.0:28335"
2024-12-07T00:11:37Z Using at most 125 automatic connections (1048576 file descriptors available)
2024-12-07T00:11:37Z scheduler thread start
2024-12-07T00:11:37Z Binding RPC on address 10.21.21.8 port 8332
2024-12-07T00:11:37Z Binding RPC on address 127.0.0.1 port 8332
2024-12-07T00:11:37Z Using random cookie authentication.
2024-12-07T00:11:37Z Generated RPC authentication cookie /data/.bitcoin/.cookie
2024-12-07T00:11:37Z Permissions used for cookie: rw-------
2024-12-07T00:11:37Z Using rpcauth authentication.
2024-12-07T00:11:37Z Starting HTTP server with 4 worker threads
2024-12-07T00:11:37Z Using wallet directory /data/.bitcoin
2024-12-07T00:11:37Z init message: Verifying wallet(s)…
2024-12-07T00:11:37Z Using /16 prefix for IP bucketing
2024-12-07T00:11:37Z init message: Loading P2P addresses…
2024-12-07T00:11:37Z Loaded 0 addresses from peers.dat 0ms
2024-12-07T00:11:37Z init message: Loading banlist…
2024-12-07T00:11:37Z banlist.dat ignored because it can only be read by Bitcoin Core version 22.x. Remove "/data/.bitcoin/banlist.dat" to silence this warning.
2024-12-07T00:11:37Z SetNetworkActive: true
2024-12-07T00:11:37Z Cache configuration:
2024-12-07T00:11:37Z * Using 2.0 MiB for block index database
2024-12-07T00:11:37Z * Using 53.4 MiB for transaction index database
2024-12-07T00:11:37Z * Using 46.7 MiB for basic block filter index database
2024-12-07T00:11:37Z * Using 8.0 MiB for chain state database
2024-12-07T00:11:37Z * Using 318.9 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2024-12-07T00:11:37Z [error] Failed to initialize ChainstateManager: AutoFile::read: end of file: iostream error
2024-12-07T00:11:37Z Shutdown: In progress...
2024-12-07T00:11:37Z scheduler thread exit
2024-12-07T00:11:37Z Flushed fee estimates to fee_estimates.dat.
2024-12-07T00:11:37Z Shutdown: done
2024-12-07T00:12:38Z Ignoring unknown configuration value maxtimeadjustment
2024-12-07T00:12:38Z Included configuration file umbrel-bitcoin.conf
2024-12-07T00:12:38Z Bitcoin Core version v28.0.0 (release build)
2024-12-07T00:12:38Z parameter interaction: -proxy set -> setting -upnp=0
2024-12-07T00:12:38Z parameter interaction: -proxy set -> setting -natpmp=0
2024-12-07T00:12:38Z parameter interaction: -proxy set -> setting -discover=0
2024-12-07T00:12:38Z Script verification uses 3 additional threads
2024-12-07T00:12:38Z Using the 'standard' SHA256 implementation
2024-12-07T00:12:38Z Default data directory /data/.bitcoin
2024-12-07T00:12:38Z Using data directory /data/.bitcoin
2024-12-07T00:12:38Z Config file: /data/.bitcoin/bitcoin.conf
2024-12-07T00:12:38Z Config file arg: bantime="86400"
2024-12-07T00:12:38Z Config file arg: blockfilterindex="1"
2024-12-07T00:12:38Z Config file arg: datacarriersize="83"
2024-12-07T00:12:38Z Config file arg: dbcache="429"
2024-12-07T00:12:38Z Config file arg: i2pacceptincoming="0"
2024-12-07T00:12:38Z Config file arg: i2psam="10.21.22.11:7656"
2024-12-07T00:12:38Z Config file arg: includeconf="umbrel-bitcoin.conf"
2024-12-07T00:12:38Z Config file arg: listen="1"
2024-12-07T00:12:38Z Config file arg: listenonion="0"
2024-12-07T00:12:38Z Config file arg: maxconnections="125"
2024-12-07T00:12:38Z Config file arg: maxmempool="300"
2024-12-07T00:12:38Z Config file arg: maxorphantx="100"
2024-12-07T00:12:38Z Config file arg: maxreceivebuffer="5000"
2024-12-07T00:12:38Z Config file arg: maxsendbuffer="1000"
2024-12-07T00:12:38Z Config file arg: maxuploadtarget="0"
2024-12-07T00:12:38Z Config file arg: mempoolexpiry="336"
2024-12-07T00:12:38Z Config file arg: onion="10.21.22.10:9050"
2024-12-07T00:12:38Z Config file arg: onlynet="ipv4"
2024-12-07T00:12:38Z Config file arg: onlynet="ipv6"
2024-12-07T00:12:38Z Config file arg: onlynet="onion"
2024-12-07T00:12:38Z Config file arg: onlynet="i2p"
2024-12-07T00:12:38Z Config file arg: peerblockfilters="1"
2024-12-07T00:12:38Z Config file arg: peertimeout="60"
2024-12-07T00:12:38Z Config file arg: persistmempool="1"
2024-12-07T00:12:38Z Config file arg: proxy="10.21.22.10:9050"
2024-12-07T00:12:38Z Config file arg: rpcworkqueue="128"
2024-12-07T00:12:38Z Config file arg: timeout="5000"
2024-12-07T00:12:38Z Config file arg: torcontrol="10.21.22.10:9051"
2024-12-07T00:12:38Z Config file arg: torpassword=****
2024-12-07T00:12:38Z Config file arg: txindex="1"
2024-12-07T00:12:38Z Config file arg: whitelist="10.21.0.0/16"
2024-12-07T00:12:38Z Config file arg: [main] bind="0.0.0.0:8333"
2024-12-07T00:12:38Z Config file arg: [main] bind="10.21.21.8:8334=onion"
2024-12-07T00:12:38Z Command-line arg: deprecatedrpc="create_bdb"
2024-12-07T00:12:38Z Command-line arg: deprecatedrpc="warnings"
2024-12-07T00:12:38Z Command-line arg: port="8333"
2024-12-07T00:12:38Z Command-line arg: rpcallowip="10.21.0.0/16"
2024-12-07T00:12:38Z Command-line arg: rpcallowip="127.0.0.1"
2024-12-07T00:12:38Z Command-line arg: rpcauth=****
2024-12-07T00:12:38Z Command-line arg: rpcbind="10.21.21.8"
2024-12-07T00:12:38Z Command-line arg: rpcbind="127.0.0.1"
2024-12-07T00:12:38Z Command-line arg: rpcport="8332"
2024-12-07T00:12:38Z Command-line arg: zmqpubhashblock="tcp://0.0.0.0:28334"
2024-12-07T00:12:38Z Command-line arg: zmqpubrawblock="tcp://0.0.0.0:28332"
2024-12-07T00:12:38Z Command-line arg: zmqpubrawtx="tcp://0.0.0.0:28333"
2024-12-07T00:12:38Z Command-line arg: zmqpubsequence="tcp://0.0.0.0:28335"
2024-12-07T00:12:38Z Using at most 125 automatic connections (1048576 file descriptors available)
2024-12-07T00:12:38Z scheduler thread start
2024-12-07T00:12:38Z Binding RPC on address 10.21.21.8 port 8332
2024-12-07T00:12:38Z Binding RPC on address 127.0.0.1 port 8332
2024-12-07T00:12:38Z Using random cookie authentication.
2024-12-07T00:12:38Z Generated RPC authentication cookie /data/.bitcoin/.cookie
2024-12-07T00:12:38Z Permissions used for cookie: rw-------
2024-12-07T00:12:38Z Using rpcauth authentication.
2024-12-07T00:12:38Z Starting HTTP server with 4 worker threads
2024-12-07T00:12:38Z Using wallet directory /data/.bitcoin
2024-12-07T00:12:38Z init message: Verifying wallet(s)…
2024-12-07T00:12:38Z Using /16 prefix for IP bucketing
2024-12-07T00:12:38Z init message: Loading P2P addresses…
2024-12-07T00:12:38Z Loaded 0 addresses from peers.dat 0ms
2024-12-07T00:12:38Z init message: Loading banlist…
2024-12-07T00:12:38Z banlist.dat ignored because it can only be read by Bitcoin Core version 22.x. Remove "/data/.bitcoin/banlist.dat" to silence this warning.
2024-12-07T00:12:38Z SetNetworkActive: true
2024-12-07T00:12:38Z Cache configuration:
2024-12-07T00:12:38Z * Using 2.0 MiB for block index database
2024-12-07T00:12:38Z * Using 53.4 MiB for transaction index database
2024-12-07T00:12:38Z * Using 46.7 MiB for basic block filter index database
2024-12-07T00:12:38Z * Using 8.0 MiB for chain state database
2024-12-07T00:12:38Z * Using 318.9 MiB for in-memory UTXO set (plus up to 286.1 MiB of unused mempool space)
2024-12-07T00:12:38Z [error] Failed to initialize ChainstateManager: AutoFile::read: end of file: iostream error
2024-12-07T00:12:38Z Shutdown: In progress...
2024-12-07T00:12:38Z scheduler thread exit
2024-12-07T00:12:38Z Flushed fee estimates to fee_estimates.dat.
2024-12-07T00:12:38Z Shutdown: done
Can you imagine what the issue is? How can I fix it?
Thanks everyone that tries to help!
