Where can I find my nodes on chain xpub. I want to add it to a watch only wallet in sparrow wallet so that I can mix to it.
Side note: I’d love to have whirlpool mixing on the umbrel bitcoin wallet.
Import the umbrel seed into bluewallet, then go to wallet details and you have a button named “xpub”
Does that work even though LND uses a aezeed seed instead of BIP39?
yes BW is not importing the seed as BIP39 but as AEZEED.
You can also use Sparrow wallet to import a converted aezeed wallet into BIP84 format.
You can use this tool https://guggero.github.io/cryptography-toolkit/#!/aezeed (save the HTML file and use it in offline mode) to convert aezeed seed into MPK BIP 32.
I explained the steps in the guide for restoring Umbrel node.
In Sparrow as in Bluewallet you will see the xpub/zpub
Thanks a lot for your reply!
