I think my node is freezed. I can find him on my network with Angry IP but I can’t connect to him with SSH or Tor. Angry IP don’t show me the name or if there are open port (I know that it’s the good IP address because it the one with I connected my PC before).
Someone told me that it should be because of the node freezed.
Did you already have a similar issue and solve this problem ?
Pi’s have a micro-hdmi port, but you’d need a micro-hdmi to hdmi adapter or cable.
And yes, unfortunately if you unplug and plug the node back in, there is a chance of corruption. As long as you have seed and channel backups, you should be okay though.
If you connect it to the monitor, you can see what it’s actually outputting and potentially get access to the command line (so you can run a proper reboot).
If you’re okay with potentially just starting over, you can unplug and plug it back in. I would recommend the HDMI port first if it was me, but obviously it depends if you need to get to something.
