Node constantly resyncing after reboot
I had fully synced bitcoin node, turned RBF on in settings and it started to sync from 0 after restart.
Before it happend as well — after updates migration from Pi to Umbrel Home with 1.0 OS I had some problems with bitcoind not syncrhonising.
I did this manual update with “sudo mender install https://download.umbrel.com/release/1.0.3/umbrelos-amd64.update && sudo reboot” and it started to resync from 0 after that. In the console I saw something about If I want to “commit” or “reverse” this update, I don’t have screenshots.
It worked good until I changed RBF settings and now it syncs from scratch. I wonder If it it will happen everytime it goes offline?
What to do?
Currently have 1.0.4
Umbrel System Log Apr 8 2024.log (136.5 KB)
Bitcoin log Apr 8 2024 18-39.log (258.5 KB)
I managed to fix it. I had reindex=1 and changed it to 0
