After I upgraded to Umbrel 1.0 (flashed umbrel pi4 image.zip with balena edger to my SD card) bitcoin blockchain is not synchronizing to 100% it restarts once 14.99% is reached (block 428.179) then drops back and restart from 14.44% (block 424.179)
Can support kindly provide me with guidance to install 1.0 from scratch? do i need to erase my SD card and SSD 1TB external drive?
Thank you in advance for your support.
Hi @JohnSTA sorry to hear about your issue here.
I believe we should be able to resolve this. Just to help us identify the specific issue, can you please navigate to the Settings (http:umbrel.local/settings) > Troubleshoot > Bitcoin Then click on “Download Bitcoin node logs”, and please send us the log file here.
Otherwise, you can use this guide here to reformat your SSD to start again.
Hi Smolgrrr,
Please find hereby attached the node log files.
(Attachment Unconfirmed 363471.crdownload is missing)
Hi smolgrrr,
Hereby attached the log files, thanks a mill for your support.
Unconfirmed 363471.log (35.7 KB)
Hmmm interesting, there doesn’t seem to be any issues documented here. Did you recently reinstall Bitcoin Core?
May I ask what sync percentage it is at right now?
Hi Smolgrrr,
I am on holidays till 03/06 not sure if i can check remotely my RPI node, i try to check one of these and get back to you later.
Hopefully the node continued synchronizing in the background.
Regards
Send from iPhone12
