No Web-Login, only SSH
Hello,
just arrived in CostaRica and trying to get up my umbrel node.
Running raspberry pi 4GB, 1TB SSD, connected via ethernet cable to router.
Umbrel version 0.4.17. … however fresh flashed.
I can access the node via SSH but in no means via web… not “umbrel.local”…not via “192.168…”.
Any further leads?
Is the device from which you try to access it on the same internet connection (wifi)?
