Hello guys,
Running my node on PI5 and Umbrel 1.3, i used to access my node through the remote acces via Tor’s onion address.
For a few days now, i can’t access anymore.
Tried to access via 192.168 and via umbrel.local with the same error message:
'Address Not Found
The browser could not find the host server for the provided address.
Check the address for typing errors such as ww.example.com instead of www.example.com.
If you are unable to load any pages, check your device’s data or Wi-Fi connection.'
From outside my PI seems to work perfectly. Green led is flashing
Orange led is permanently
Thanks for your help
