After a hard reboot i cannot access umbrel from Zeus, i get the message:
“unable to resolve host [onion address] no address associated with hostname”
but I still can access umbrel via tor. How can i fix this?
Just try again, is Tor making problems.
Or use the new app in Umbrel, Tailscale, making a private VPN to your node and connect through that. Works perfect.
As you said, tor is a troublemaker. After 15 hours it works again. I will consider tailscale in the future, thank you.
