My SSD is corrupted
I get below output in Logfile. Looks like my SSD is corrupted. Does anyone know how to recover form this ? I already tried pointing to a new superblock via fsck -b option but no luck.
Any help appreciated.
External storage service logs
– Logs begin at Tue 2023-02-21 08:38:13 CET, end at Tue 2023-02-21 08:40:32 CET . –
Feb 21 08:38:18 umbrel systemd[1]: Starting External Storage Mounter…
Feb 21 08:38:18 umbrel external storage mounter[555]: Running external storage m ount script…
Feb 21 08:38:18 umbrel external storage mounter[555]: Found device “WD My Passpo rt 261B”
Feb 21 08:38:18 umbrel external storage mounter[555]: Blacklisting USB device ID s against UAS driver…
Feb 21 08:38:18 umbrel external storage mounter[555]: Checking USB devices are b ack…
Feb 21 08:38:18 umbrel external storage mounter[555]: Checking if the device is ext4…
Feb 21 08:38:18 umbrel external storage mounter[555]: Yes, it is ext4
Feb 21 08:38:18 umbrel external storage mounter[555]: Checking filesystem for co rruption…
Feb 21 08:38:18 umbrel external storage mounter[555]: e2fsck 1.44.5 (15-Dec-2018 )
Feb 21 08:38:19 umbrel external storage mounter[555]: umbrel: recovering journal
Feb 21 08:38:24 umbrel external storage mounter[555]: fsck.ext4: No such file or directory while trying to re-open umbrel
Feb 21 08:38:24 umbrel external storage mounter[555]: umbrel: ********** WARNING : Filesystem still has errors **********
Feb 21 08:38:24 umbrel external storage mounter[555]: Mounting partition…
Feb 21 08:38:24 umbrel external storage mounter[555]: mount: /mnt/data: special device /dev/sda1 does not exist.
Feb 21 08:38:24 umbrel external storage mounter[555]: Error mounting partition
Feb 21 08:38:24 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Feb 21 08:38:24 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Feb 21 08:38:24 umbrel systemd[1]: Failed to start External Storage Mounter.
There is not really an option. Your SSD file system is corrupted.
You can try to fix the filesystem. If this is not working you can try to format your SSD and if this is not working you need a new SSD.
Thanks @rieger_san , I feared as much. New SSD ordered, hope node is up and running again in a few days.
