After we had a power outage, I cannot connect to my umbrel anymore via web.
By going trough the logs I noticed the following:
Aug 20 12:52:30 umbrel systemd[1]: Failed to start External Storage Mounter.
I already tried to change the cable and the USB port of the external hard drive but the issue keeps popping up.
Any idea what I could look into next?
Below the full log of my umbrel.
Thank you for your help already!
0.5.1
Flashed OS version
v0.4.15
Raspberry Pi Model
Revision : c03114
Serial : 1000000091b87428
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=33.6’C
Throttling
throttled=0x0
Mem: 3.8G 133M 3.4G 8.0M 220M 3.6G
Swap: 0B 0B 0B
total: 3.5%
system: 3.5%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root 59G 3.4G 53G 6% /
Startup service logs
– Logs begin at Sat 2022-08-20 12:52:19 UTC, end at Sat 2022-08-20 13:09:53 UTC. –
Aug 20 12:52:30 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Aug 20 12:52:30 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Aug 20 12:52:24 umbrel systemd[1]: Starting External Storage Mounter…
Aug 20 12:52:24 umbrel external storage mounter[472]: Running external storage mount script…
Aug 20 12:52:24 umbrel external storage mounter[472]: Found device “Samsung PSSD T7”
Aug 20 12:52:24 umbrel external storage mounter[472]: Blacklisting USB device IDs against UAS driver…
Aug 20 12:52:24 umbrel external storage mounter[472]: Rebinding USB drivers…
Aug 20 12:52:24 umbrel external storage mounter[472]: Checking USB devices are back…
Aug 20 12:52:24 umbrel external storage mounter[472]: Waiting for USB devices…
Aug 20 12:52:25 umbrel external storage mounter[472]: Waiting for USB devices…
Aug 20 12:52:26 umbrel external storage mounter[472]: Waiting for USB devices…
Aug 20 12:52:27 umbrel external storage mounter[472]: Checking if the device is ext4…
Aug 20 12:52:28 umbrel external storage mounter[472]: Yes, it is ext4
Aug 20 12:52:30 umbrel external storage mounter[472]: mount: /mnt/data: can’t read superblock on /dev/sda1.
Aug 20 12:52:30 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=32/n/a
Aug 20 12:52:30 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Aug 20 12:52:30 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Aug 20 12:52:30 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor logs
==== Result ====
