After install Portainer, my Bitcoin Node does not open any more. Portainer does not open too.
After remove Portainer Bitcoin Node start.
Reinstall Portainer and i have thins in “troubleshot”
portainer_app_proxy_1 | yarn run v1.22.19
portainer_app_proxy_1 | warning Skipping preferred cache folder "/home/node/.cache/yarn" because it is not writable.
portainer_app_proxy_1 | warning Skipping preferred cache folder "/tmp/.yarn-cache-1000" because it is not writable.
portainer_app_proxy_1 | warning Skipping preferred cache folder "/tmp/.yarn-cache" because it is not writable.
portainer_app_proxy_1 | info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
portainer_app_proxy_1 | error Yarn hasn't been able to find a cache folder it can use. Please use the explicit --cache-folder option to tell it what location to use, or make one of the preferred locations writable.
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:369 > encryption key file not present | filename=portainer
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:392 > proceeding without encryption key |
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/database/boltdb/db.go:125 > loading PortainerDB | filename=portainer.db
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:552 > instance already has an administrator user defined, skipping admin password related flags. |
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/chisel/service.go:197 > Found Chisel private key file on disk | private-key=/data/chisel/private-key.pem
portainer_portainer_1 | 2024/05/29 18:08:09 server: Reverse tunnelling enabled
portainer_portainer_1 | 2024/05/29 18:08:09 server: Fingerprint QrxrR4rpUHP0lrtxF9vQa0lR7bFTjTzW86TLEgPNdAY=
portainer_portainer_1 | 2024/05/29 18:08:09 server: Listening on http://0.0.0.0:8000
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/cmd/portainer/main.go:649 > starting Portainer | build_number=34749 go_version=1.20.5 image_tag=linux-amd64-2.19.1 nodejs_version=18.18.0 version=2.19.1 webpack_version=5.88.1 yarn_version=1.22.19
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/http/server.go:356 > starting HTTPS server | bind_address=:9443
portainer_portainer_1 | 2024/05/29 06:08PM INF github.com/portainer/portainer/api/http/server.go:340 > starting HTTP server | bind_address=:9000
portainer_docker_1 | Bridge 'dind0' already exists. Skipping creation.
portainer_docker_1 | 17: dind0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN qlen 1000
portainer_docker_1 | link/ether fa:87:f9:2b:31:c8 brd ff:ff:ff:ff:ff:ff
portainer_docker_1 | inet 10.32.0.1/16 scope global dind0
portainer_docker_1 | valid_lft forever preferred_lft forever
portainer_docker_1 | time="2024-05-29T18:08:08.212576859Z" level=info msg="Starting up"
portainer_docker_1 | time="2024-05-29T18:08:08.213864052Z" level=warning msg="could not change group /data/docker.sock to docker: group docker not found"
portainer_docker_1 | time="2024-05-29T18:08:08.214154967Z" level=info msg="containerd not running, starting managed containerd"
portainer_docker_1 | time="2024-05-29T18:08:08.215115037Z" level=info msg="started new containerd process" address=/data/exec/containerd/containerd.sock module=libcontainerd pid=36
portainer_docker_1 | time="2024-05-29T18:08:08.243522140Z" level=info msg="starting containerd" revision=1677a17964311325ed1c31e2c0a3589ce6d5c30d version=v1.7.1
portainer_docker_1 | time="2024-05-29T18:08:08.265775890Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.aufs\"..." type=io.containerd.snapshotter.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280226349Z" level=info msg="skip loading plugin \"io.containerd.snapshotter.v1.aufs\"..." error="aufs is not supported (modprobe aufs failed: exit status 1 \"ip: can't find device 'aufs'\\nmodprobe: can't change directory to '/lib/modules': No such file or directory\\n\"): skip plugin" type=io.containerd.snapshotter.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280273114Z" level=info msg="loading plugin \"io.containerd.content.v1.content\"..." type=io.containerd.content.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280309325Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.native\"..." type=io.containerd.snapshotter.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280335538Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.overlayfs\"..." type=io.containerd.snapshotter.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280471179Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.devmapper\"..." type=io.containerd.snapshotter.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280488248Z" level=warning msg="failed to load plugin io.containerd.snapshotter.v1.devmapper" error="devmapper not configured"
portainer_docker_1 | time="2024-05-29T18:08:08.280534238Z" level=info msg="loading plugin \"io.containerd.snapshotter.v1.zfs\"..." type=io.containerd.snapshotter.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280669112Z" level=info msg="skip loading plugin \"io.containerd.snapshotter.v1.zfs\"..." error="path /data/data/containerd/daemon/io.containerd.snapshotter.v1.zfs must be a zfs filesystem to be used with the zfs snapshotter: skip plugin" type=io.containerd.snapshotter.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280686801Z" level=info msg="loading plugin \"io.containerd.metadata.v1.bolt\"..." type=io.containerd.metadata.v1
portainer_docker_1 | time="2024-05-29T18:08:08.280707756Z" level=warning msg="could not use snapshotter devmapper in metadata plugin" error="devmapper not configured"
portainer_docker_1 | time="2024-05-29T18:08:08.280718348Z" level=info msg="metadata content store policy set" policy=shared
portainer_docker_1 | time="2024-05-29T18:08:08.286983062Z" level=info msg="loading plugin \"io.containerd.differ.v1.walking\"..." type=io.containerd.differ.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287033414Z" level=info msg="loading plugin \"io.containerd.event.v1.exchange\"..." type=io.containerd.event.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287052001Z" level=info msg="loading plugin \"io.containerd.gc.v1.scheduler\"..." type=io.containerd.gc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287078237Z" level=info msg="loading plugin \"io.containerd.lease.v1.manager\"..." type=io.containerd.lease.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287092391Z" level=info msg="loading plugin \"io.containerd.nri.v1.nri\"..." type=io.containerd.nri.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287107214Z" level=info msg="NRI interface is disabled by configuration."
portainer_docker_1 | time="2024-05-29T18:08:08.287118968Z" level=info msg="loading plugin \"io.containerd.runtime.v2.task\"..." type=io.containerd.runtime.v2
portainer_docker_1 | time="2024-05-29T18:08:08.287214196Z" level=info msg="loading plugin \"io.containerd.runtime.v2.shim\"..." type=io.containerd.runtime.v2
portainer_docker_1 | time="2024-05-29T18:08:08.287235247Z" level=info msg="loading plugin \"io.containerd.sandbox.store.v1.local\"..." type=io.containerd.sandbox.store.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287249549Z" level=info msg="loading plugin \"io.containerd.sandbox.controller.v1.local\"..." type=io.containerd.sandbox.controller.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287277094Z" level=info msg="loading plugin \"io.containerd.streaming.v1.manager\"..." type=io.containerd.streaming.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287293507Z" level=info msg="loading plugin \"io.containerd.service.v1.introspection-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287305822Z" level=info msg="loading plugin \"io.containerd.service.v1.containers-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287317790Z" level=info msg="loading plugin \"io.containerd.service.v1.content-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287341351Z" level=info msg="loading plugin \"io.containerd.service.v1.diff-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287356873Z" level=info msg="loading plugin \"io.containerd.service.v1.images-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287369584Z" level=info msg="loading plugin \"io.containerd.service.v1.namespaces-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287381284Z" level=info msg="loading plugin \"io.containerd.service.v1.snapshots-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287392087Z" level=info msg="loading plugin \"io.containerd.runtime.v1.linux\"..." type=io.containerd.runtime.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287449108Z" level=info msg="loading plugin \"io.containerd.monitor.v1.cgroups\"..." type=io.containerd.monitor.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287727720Z" level=info msg="loading plugin \"io.containerd.service.v1.tasks-service\"..." type=io.containerd.service.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287766997Z" level=info msg="loading plugin \"io.containerd.grpc.v1.introspection\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287783727Z" level=info msg="loading plugin \"io.containerd.transfer.v1.local\"..." type=io.containerd.transfer.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287811425Z" level=info msg="loading plugin \"io.containerd.internal.v1.restart\"..." type=io.containerd.internal.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287871183Z" level=info msg="loading plugin \"io.containerd.grpc.v1.containers\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287941737Z" level=info msg="loading plugin \"io.containerd.grpc.v1.content\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287957036Z" level=info msg="loading plugin \"io.containerd.grpc.v1.diff\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287969503Z" level=info msg="loading plugin \"io.containerd.grpc.v1.events\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287982386Z" level=info msg="loading plugin \"io.containerd.grpc.v1.healthcheck\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.287994293Z" level=info msg="loading plugin \"io.containerd.grpc.v1.images\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288005585Z" level=info msg="loading plugin \"io.containerd.grpc.v1.leases\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288016703Z" level=info msg="loading plugin \"io.containerd.grpc.v1.namespaces\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288029674Z" level=info msg="loading plugin \"io.containerd.internal.v1.opt\"..." type=io.containerd.internal.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288326966Z" level=info msg="loading plugin \"io.containerd.grpc.v1.sandbox-controllers\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288346337Z" level=info msg="loading plugin \"io.containerd.grpc.v1.sandboxes\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288358506Z" level=info msg="loading plugin \"io.containerd.grpc.v1.snapshots\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288370002Z" level=info msg="loading plugin \"io.containerd.grpc.v1.streaming\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288381918Z" level=info msg="loading plugin \"io.containerd.grpc.v1.tasks\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288396485Z" level=info msg="loading plugin \"io.containerd.grpc.v1.transfer\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288407828Z" level=info msg="loading plugin \"io.containerd.grpc.v1.version\"..." type=io.containerd.grpc.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288419563Z" level=info msg="loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." type=io.containerd.tracing.processor.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288434900Z" level=info msg="skip loading plugin \"io.containerd.tracing.processor.v1.otlp\"..." error="no OpenTelemetry endpoint: skip plugin" type=io.containerd.tracing.processor.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288449903Z" level=info msg="loading plugin \"io.containerd.internal.v1.tracing\"..." type=io.containerd.internal.v1
portainer_docker_1 | time="2024-05-29T18:08:08.288460471Z" level=info msg="skipping tracing processor initialization (no tracing plugin)" error="no OpenTelemetry endpoint: skip plugin"
portainer_docker_1 | time="2024-05-29T18:08:08.288843490Z" level=info msg=serving... address=/data/exec/containerd/containerd-debug.sock
portainer_docker_1 | time="2024-05-29T18:08:08.289036501Z" level=info msg=serving... address=/data/exec/containerd/containerd.sock.ttrpc
portainer_docker_1 | time="2024-05-29T18:08:08.289175263Z" level=info msg=serving... address=/data/exec/containerd/containerd.sock
portainer_docker_1 | time="2024-05-29T18:08:08.289208839Z" level=info msg="containerd successfully booted in 0.046546s"
portainer_docker_1 | time="2024-05-29T18:08:08.394969113Z" level=info msg="[graphdriver] using prior storage driver: overlay2"
portainer_docker_1 | time="2024-05-29T18:08:08.395242819Z" level=info msg="Loading containers: start."
portainer_docker_1 | time="2024-05-29T18:08:09.155379146Z" level=info msg="Loading containers: done."
portainer_docker_1 | time="2024-05-29T18:08:09.179579170Z" level=info msg="Docker daemon" commit=a61e2b4 graphdriver=overlay2 version=24.0.5
portainer_docker_1 | time="2024-05-29T18:08:09.179708431Z" level=info msg="Daemon has completed initialization"
portainer_docker_1 | time="2024-05-29T18:08:09.222714523Z" level=info msg="API listen on /data/docker.sock"
