Multiple SSDs on MiniPC
Hi all, I have just set up Umbrel on this beast.
Currently just have a 1TB SSD installed in it which is where I have installed the OS. Question, can I have multiple SSDs installed and use all available storage? I basically have a Bitcoin Umbrel and a Plex Umbrel that I want to consolidate into one.
Also having trouble using Wifi on the beast - any help on that please?
Any help please?
What we would need to do is set up is a LVM group and volume. This is a special linux volume where it can span its disk space across many drives or partitions.
So is the a Nas unit, a bitcoin computer and a Plex compuer?
or there is just two machines (nas with bitcoin and another with plex)
Because the solution is to copy the one docker container onto the LVM volume then span it across multiple drives and partitions as one volume while merging data onto the LVM volume
It’ll be one machine with multiple SSDs. Would I be better running Linux on it, turning the drives into RAID format then installing Umbrel?
The system that Umbrel runs on is Debian 12 (Bookworm) without a desktop gui. Umbrel is what is called a Docker desktop. But to move any active system folders on any Linux system, you have to be booted from a USB or CD rom to copy folders it locks when that system is active.
The Umbrel/Debain install they have don’t give you much room to install the desktop GUI other than the x-windows kiosk which is fine if you needed to use that instead of the web address. I extend that drive so I can run a full Linux desktop and programs.
You could go a different route, and copy the /home folder it mounts. If you just want to just expand the Umbrel Docker, but I would recommend formatting the new /home drive in LVM so you can expand it later. I copy and expand the whole docker system because mounting the 1TB drive in home is only going to get you 1TB to install for programs. Which /home directory is used to install user programs in Linux and the blockchain you want to install will instantly fill 65% of that drive (680GB plus database and program).
Lets look at the default install for umbrel:
/dev/disk/by-partuuid/14a31e9d-a8d7-4da0-9eb2-f268dd9d7ad9   /boot/efi          auto       defaults,sync    0  0
/dev/root            /                    auto       defaults,x-systemd.growfs 1  1
/dev/disk/by-partuuid/d1d36e34-2753-4dc7-96eb-3c9b5584e867   /data          auto       defaults,x-systemd.growfs      0  0
/dev/mapper/umbrel_vol-umbrel_docker /data  auto defaults 0 0
# entries kept from original fstab
# <device>                                  <dir>                        <type>      <options>   <dump>  <fsck>
/                                           /mnt/root                    none        bind        0       0
/data/umbrel-os/var/log                     /var/log                     none        bind        0       0
/data/umbrel-os/var/lib/docker              /var/lib/docker              none        bind        0       0
/data/umbrel-os/home                        /home                        none        bind        0       0
/data/umbrel-os/var/lib/systemd/timesync    /var/lib/systemd/timesync    none        bind        0       0
So when you boot the computer with a live linux usb, (which I use Ubuntu for this so I have all the disk tools preinstalled on it) I launch Gparted, partition and format the 1TB drive, then mount the /data partition of umbrel with the file manager (which is going to be the largest unmounted partition when you exit out of Ubuntu’s setup and go to the live desktop), then copy /data/umbrel-os/home to the 1TB. Then either move /data/umbrel-os/home to a different folder like /data/umbrel-os/home_old and make a new /data/umbrel-os/home or delete the contents of /data/umbrel-os/home so its empty so you can mount the 1TB drive there. Then find the 1TB drive’s UUID with sudo lsblk -f , mount the Debian Linux partition on the Umbrel install (about 4Gb) and edit the /etc/fstab,
Then reboot.
This process is similar to moving a Linux OS /home, however, with a docker desktop /home you have to boot a live linux and move the home folder because the web desktop has to be not running which this one is installed in the /data/umbrel-os/home/umbrel/umbrel/home/
LVM isn’t really a raid. You could simulate a software raid of sorts, but the difference between hat and a RAID, software or hardware, there is automation for swapping in redundant drives/partitions if they go out. LVM alone doesn’t do that.
