SSD / HDD & Backup?
I’m looking for the best way to manage the SSD/HDD with Umbrel on my Raspberry Pi 4. I want to run a Bitcoin node and use some apps. Should I use 2 SSD, one for the node and one for the app datas (photos, medias…) then backup occasionally the SSD with my medias manually to another disk in case of disk failure? And what about Internal disk + adapter? Thanks
I’d recommend a single, high-storage SSD. I’m running 1TB on my Umbrel, with Bitcoin Core taking up 630GB, which leaves plenty of space for other apps/data, but you might want more.
Looks a little intensive running blocks data from a different HDD →
