Trying to understand the limitation on multiple drives
I’m about to try out Umbrel on the following setup:
  • RasPi 4 4GB
  • Umbrel 0.5 burned onto 16GB microSD card
  • Ethernet connection
  • Argon Eon NAS
  • 1 x 4TB SSD, 1 x 4TB HD, 1 x 2TB HD
Is it not possible to install Umbrel on a multiple-drive machine at all?
Would I be able to install it first by pulling out 2 of the drives and then add them in later?
If not, what’s the rationale here?
I’ve hunted through the forums for an answer but it seems the assumption here is no-one would ever add more than one drive.
I second this. I would like to have things like Media files on spinning rust and the Umbrel and perhaps stuff like Bitcoin and Lightning on an SSD
@suranyami @JanHolbo
Any of you guys have managed to run Umbrel on a multiple-drive machine?
I am also considering to buy an Argon Eon NAS enclosure, and was wondering how to set up a second drive in there (mirroring via RAID). Any hints for setup appreciated!
Especially now, since Umbrel can be installed directly onto the drives, this use case should become more interesting perhaps. Officially supported on Pi5, but has also been reported to work on Pi4, which the Argon Eon case is made for.
Perhaps this guide might be useful:
If not, maybe it can be done using a Logical Volume Manager?
