Monero is forbidden in my country... how do I force Monero node or Umbrel to go ONLY through Tor ?
Hello guys,
Monero is forbidden in my country. It is not only forbidden to buy it on exchanges, it is forbidden to use it.
I put Umbrel OS on a RP at home, with a Bitcoin node that I configured to connect only through Tor.
I then installed the Monero node, I checked the options and saw that Tor connection was already activated, great.
Then I looked at the connections to Peers… and I saw that all the peers connections were on the Clearnet.
I had no choice but to uninstall Monero Node immediatly. Unfortunately, it means my ISP loggued that there was a Monero node connecting to other nodes from my IP address.
The Bitcoin Node allows to deactivate all connections on Clearnet. Is there a way to do the same here ?
Alternatively, how do I force Monero node or Umbrel to go ONLY through Tor ?
I also have the same issue, The connection through Tor does not work!
Have you found any solution to it so far?
