Trying to load up my Raspberry Pi for first time. Not loading from http://umbrel/
Did IP scan and arp -a through terminal on mac
and can see the device, but MAC address shows as “at (incomplete)”
Unable to open in browser with IP address.
? stuck…
Very low level computer knowledge, so please keep any answers as simple as possible. Many thanks in advance.
A few things to help you troubleshoot.
- make sure you’re trying to load http://umbrel.local/
- make sure your browser loads http not https
- Try a network scan with nmap https://nmap.org/book/inst-macosx.html
- run ping scan on nmap >> nmap -sn {{insert router IP}}/24
- See if this returns different info on the Pi MAC and IP address
Hope that helps.
Thanks for support. Tried a few things. But the answer lay in the ethernet cable. Plugged it into a different line and viola!
