Lightning Node stuck on ...starting / can log in, but can't ssh
My primary node went down recently. Ended up with a New router, spare node pi and a new microSD to get it back up.
I can log into the ip through my browser no problem. But my Lightning Node Icon is stuck blinking in Starting… And I cannot ssh in. Keeps giving me connection refused.
hmm difficult…
LND broken but ssh should still work.
when you can’t manually stop the docker it’s bad.
maybe reinstall the app (if possible and you have an backup).
otherwise try new umbrel os on micro sd data should stay on the ssd
cheers
Finally got Lightning to reboot. And with the router change I had to go find my localhost and change the SHA key since I was now on my spare node’s ip.
