Hi there! Somebody know is this on starup LN app? thanks
Oops, there was an error
There was an error connecting to Lightning Node. Error code: ECONNREFUSED
The best fix for this is to restart via System > Restart
If this doesn’t solve the issue could you share a full debug log?
For reference check out FAQ under “Generating Troubleshooting Logs” here: Official Umbrel Troubleshooting Guide and FAQ - Guides - Umbrel Community
System > Troubleshoot > Start and it will generate it from you right there within the dashboard and download it, then you can paste it to www.pastebin.com and share a link for easy review
If for any reason you are unable to generate from the UI
You can SSH via the steps from “How to SSH” and copy the output of this command for the log:
sudo ~/umbrel/scripts/debug
helow bro
Thanks!
I resolve
Was watch tower error line in lnd.conf
thanks!
