After 5.4 update, lighting node won’t start completely.
Have tried the following:
- Bitcoin node is 100% synced
- Restart of umbrel from both app and command line
- Have added “reset-wallet-transactions=true” to lnd.conf (only 1 or 2 transactions for initial receive)
- Stop + sudo rm -f .env && sudo ./scripts/configure + start
Seeing this after restart:
Progress bar doesn’t advance after 24hrs and eventually throws error (ENOTFOUND)
Logs:
umbrel@umbrel:~ $ sudo ~/umbrel/scripts/debug
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : c03111
Serial : 100000002da67290
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=46.7’C
Throttling
throttled=0x0
Mem: 3.8G 2.9G 340M 7.0M 571M 829M
Swap: 4.1G 2.0G 2.1G
total: 76.0%
mempool: 26.3%
bitcoin: 25.4%
system: 9.9%
electrs: 6.9%
lightning: 3.2%
core-lightning: 2.6%
jam: 1.1%
btc-rpc-explorer: 0.6%
Memory monitor logs
2023-08-28 01:37:02 Memory monitor running!
2023-08-28 01:37:15 Memory monitor running!
9104 ? S 0:00 bash ./scripts/memory-monitor
2023-09-03 22:14:26 Memory monitor running!
993 ? S 0:00 bash ./scripts/memory-monitor
2023-09-03 22:24:37 Memory monitor running!
2023-09-04 16:33:27 Memory monitor running!
2023-09-04 18:28:15 Memory monitor running!
/dev/root 30G 3.8G 25G 14% /
/dev/sda1 916G 651G 219G 75% /home/umbrel/umbrel
Startup service logs
Sep 04 16:34:18 umbrel umbrel startup[991]: Creating mempool_mariadb_1 … done
Sep 04 16:34:18 umbrel umbrel startup[991]: Creating mempool_web_1 … done
Sep 04 16:34:18 umbrel umbrel startup[991]: Creating lightning_lnd_1 … done
Sep 04 16:34:18 umbrel umbrel startup[991]: Creating lightning_app_proxy_1 … done
Sep 04 16:34:18 umbrel umbrel startup[991]: Creating mempool_api_1 … done
Sep 04 16:34:19 umbrel umbrel startup[991]: Creating mempool_app_proxy_1 … done
Sep 04 16:34:19 umbrel umbrel startup[991]: Creating electrs_tor_1 … done
Sep 04 16:34:20 umbrel umbrel startup[991]: Creating core-lightning_tor_1 … done
Sep 04 16:34:21 umbrel umbrel startup[991]: Creating core-lightning_app_1 … done
Sep 04 16:34:21 umbrel umbrel startup[991]: Creating core-lightning_tor_server_1 … done
Sep 04 16:34:21 umbrel umbrel startup[991]: Creating electrs_tor_server_1 … done
Sep 04 16:34:22 umbrel umbrel startup[991]: Creating bitcoin_tor_server_1 … done
Sep 04 16:34:22 umbrel umbrel startup[991]: Creating bitcoin_app_proxy_1 … done
Sep 04 16:34:22 umbrel umbrel startup[991]: Creating electrs_electrs_1 … done
Sep 04 16:34:22 umbrel umbrel startup[991]: Creating electrs_app_1 …
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating bitcoin_i2pd_daemon_1 … done
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating core-lightning_app_proxy_1 … done
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating core-lightning_c-lightning-rest_1 … done
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating electrs_app_proxy_1 … done
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating bitcoin_bitcoind_1 … done
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating bitcoin_tor_1 … done
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating bitcoin_server_1 …
Sep 04 16:34:23 umbrel umbrel startup[991]: Creating core-lightning_lightningd_1 … done
Sep 04 16:34:32 umbrel umbrel startup[991]: Creating bitcoin_server_1 … done
Sep 04 16:34:34 umbrel umbrel startup[991]: Creating electrs_app_1 … done
Sep 04 16:34:34 umbrel umbrel startup[991]: Umbrel is now accessible at
Sep 04 16:34:34 umbrel umbrel startup[991]: http://umbrel.local
Sep 04 16:34:34 umbrel umbrel startup[991]: http://192.168.1.102
Sep 04 16:34:34 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
Sep 04 16:33:13 umbrel external storage mounter[483]: Running external storage mount script…
Sep 04 16:33:13 umbrel external storage mounter[483]: Found device “WDC WDB NCE0010PNC”
Sep 04 16:33:13 umbrel external storage mounter[483]: Blacklisting USB device IDs against UAS driver…
Sep 04 16:33:13 umbrel external storage mounter[483]: Rebinding USB drivers…
Sep 04 16:33:13 umbrel external storage mounter[483]: Checking USB devices are back…
Sep 04 16:33:13 umbrel external storage mounter[483]: Waiting for USB devices…
Sep 04 16:33:14 umbrel external storage mounter[483]: Waiting for USB devices…
Sep 04 16:33:15 umbrel external storage mounter[483]: Waiting for USB devices…
Sep 04 16:33:16 umbrel external storage mounter[483]: Checking if the device is ext4…
Sep 04 16:33:16 umbrel external storage mounter[483]: Yes, it is ext4
Sep 04 16:33:16 umbrel external storage mounter[483]: Checking filesystem for corruption…
Sep 04 16:33:16 umbrel external storage mounter[483]: e2fsck 1.44.5 (15-Dec-2018)
Sep 04 16:33:17 umbrel external storage mounter[483]: umbrel: clean, 473674/61054976 files, 174488003/244190208 blocks
Sep 04 16:33:17 umbrel external storage mounter[483]: Mounting partition…
Sep 04 16:33:17 umbrel external storage mounter[483]: Checking if device contains an Umbrel install…
Sep 04 16:33:17 umbrel external storage mounter[483]: Yes, it contains an Umbrel install
Sep 04 16:33:17 umbrel external storage mounter[483]: Bind mounting external storage over local Umbrel installation…
Sep 04 16:33:17 umbrel external storage mounter[483]: Bind mounting external storage over local Docker data dir…
Sep 04 16:33:17 umbrel external storage mounter[483]: Bind mounting external storage to /swap
Sep 04 16:33:17 umbrel external storage mounter[483]: Bind mounting SD card root at /sd-card…
Sep 04 16:33:17 umbrel external storage mounter[483]: Checking Umbrel root is now on external storage…
Sep 04 16:33:18 umbrel external storage mounter[483]: Checking /var/lib/docker is now on external storage…
Sep 04 16:33:18 umbrel external storage mounter[483]: Checking /swap is now on external storage…
Sep 04 16:33:18 umbrel external storage mounter[483]: Setting up swapfile
Sep 04 16:33:19 umbrel external storage mounter[483]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Sep 04 16:33:19 umbrel external storage mounter[483]: no label, UUID=3c18e26b-ff49-42b2-8113-1fd9e4ae61ab
Sep 04 16:33:20 umbrel external storage mounter[483]: Checking SD Card root is bind mounted at /sd-root…
Sep 04 16:33:20 umbrel external storage mounter[483]: Starting external drive mount monitor…
Sep 04 16:33:20 umbrel external storage mounter[483]: Mount script completed successfully!
Sep 04 16:33:20 umbrel systemd[1]: Started External Storage Mounter.
– Logs begin at Mon 2023-09-04 16:33:06 UTC, end at Tue 2023-09-05 15:49:14 UTC. –
Sep 04 16:33:27 umbrel systemd[1]: Starting External Storage SDcard Updater…
Sep 04 16:33:27 umbrel external storage updater[913]: Checking if SD card Umbrel is newer than external storage…
Sep 04 16:33:27 umbrel external storage updater[913]: No, SD version is not newer, exiting.
Sep 04 16:33:27 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
100 8684 100 146 100 8538 61 3601 0:00:02 0:00:02 --:–:-- 3662
{“message”:“Successfully uploaded backup 1693893250112.tar.gz.pgp for backup ID 9cc06b72c0c693e130812ed52625bbd738cbaa7680b26f14be6616cf12859aaa”}
====== Backup success =======
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
3156 bytes (3.2 kB, 3.1 KiB) copied, 0.000227014 s, 13.9 MB/s
Creating encrypted tarball…
backup/
backup/channel.backup
backup/.padding
Uploading backup…
100 3957 100 146 100 3811 52 1370 0:00:02 0:00:02 --:–:-- 1422
{“message”:“Successfully uploaded backup 1693906477215.tar.gz.pgp for backup ID 9cc06b72c0c693e130812ed52625bbd738cbaa7680b26f14be6616cf12859aaa”}
Got signal: debug
Debug result file generated
Got signal: backup
Deriving keys…
Creating backup…
1+0 records in
1+0 records out
902 bytes copied, 0.00022431 s, 4.0 MB/s
backup/
backup/.padding
Uploading backup…
100 1675 100 146 100 1529 45 477 0:00:03 0:00:03 --:–:-- 523
{“message”:“Successfully uploaded backup 1693928447417.tar.gz.pgp for backup ID 9cc06b72c0c693e130812ed52625bbd738cbaa7680b26f14be6616cf12859aaa”}
Docker containers
NAMES STATUS
lightning_app_1 Up About an hour
lightning_app_proxy_1 Up About an hour
lightning_tor_1 Up About an hour
lightning_tor_server_1 Up About an hour
lightning_lnd_1 Restarting (2) 58 seconds ago
bitcoin_server_1 Up 21 hours
electrs_app_1 Up 21 hours
core-lightning_app_1 Up 21 hours
core-lightning_app_proxy_1 Up 21 hours
core-lightning_c-lightning-rest_1 Up 21 hours
core-lightning_tor_1 Up 21 hours
mempool_web_1 Up 21 hours
mempool_api_1 Up 21 hours
core-lightning_lightningd_1 Up 21 hours
mempool_mariadb_1 Up 21 hours
mempool_app_proxy_1 Up 21 hours
mempool_tor_server_1 Up 21 hours
bitcoin_bitcoind_1 Up 21 hours
core-lightning_tor_server_1 Up 21 hours
bitcoin_tor_1 Up 21 hours
electrs_electrs_1 Up 21 hours
bitcoin_app_proxy_1 Up 21 hours
electrs_tor_1 Up 21 hours
electrs_app_proxy_1 Up 21 hours
bitcoin_tor_server_1 Up 21 hours
bitcoin_i2pd_daemon_1 Up 21 hours
electrs_tor_server_1 Up 21 hours
jam_app_proxy_1 Up 21 hours
jam_web_1 Up 21 hours
btc-rpc-explorer_web_1 Up 21 hours
jam_tor_server_1 Up 21 hours
btc-rpc-explorer_app_proxy_1 Up 21 hours
btc-rpc-explorer_tor_server_1 Up 21 hours
nginx Up 21 hours
tor_server Up 21 hours
auth Up 21 hours
manager Up 21 hours
dashboard Up 21 hours
tor_proxy Up 21 hours
Umbrel logs
Attaching to manager
manager | ::ffff:10.21.21.2 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/system/info HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
manager |
manager | umbrel-manager
manager | ::ffff:10.21.21.2 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/apps?installed=1 HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/system/memory HTTP/1.0” 200 1012 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/system/update-status HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/system/storage HTTP/1.0” 200 1020 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
manager |
manager | ::ffff:10.21.0.21 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/account/token?token=d8a868e5112fe4e72170830db7465977cb5a950931f2c4f6f42c25765c4a7da4 HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager | ::ffff:10.21.0.10 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/account/token?token=d8a868e5112fe4e72170830db7465977cb5a950931f2c4f6f42c25765c4a7da4 HTTP/1.1” 200 16 “-” “app-proxy/0.0.1”
manager |
manager |
manager |
manager | ::ffff:10.21.21.2 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/system/get-update HTTP/1.0” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
manager |
Tor Proxy logs
Attaching to tor_proxy
tor_proxy | Sep 05 06:04:32.000 [warn] Received http status code 404 (“Not found”) from server 51.158.201.235:18256 while fetching “/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97”.
tor_proxy | Sep 05 06:28:21.000 [notice] Heartbeat: Tor’s uptime is 12:00 hours, with 13 circuits open. I’ve sent 14.19 MB and received 23.40 MB. I’ve received 25 connections on IPv4 and 0 on IPv6. I’ve made 13 connections with IPv4 and 0 with IPv6.
tor_proxy | Sep 05 06:28:21.000 [notice] While bootstrapping, fetched this many bytes: 733287 (consensus network-status fetch); 14358 (authority cert fetch); 11915500 (microdescriptor fetch)
tor_proxy | Sep 05 06:28:21.000 [notice] While not bootstrapping, fetched this many bytes: 408645 (consensus network-status fetch); 7356 (authority cert fetch); 1833175 (microdescriptor fetch)
tor_proxy | Sep 05 06:28:21.000 [notice] Heartbeat: Our onion service received 0 v3 INTRODUCE2 cells and attempted to launch 0 rendezvous circuits.
tor_proxy | Sep 05 07:06:33.000 [warn] Received http status code 404 (“Not found”) from server 51.158.201.235:18256 while fetching “/tor/keys/fp/EFCBE720AB3A82B99F9E953CD5BF50F7EEFC7B97”.
tor_proxy | Sep 05 12:28:21.000 [notice] Heartbeat: Tor’s uptime is 18:00 hours, with 9 circuits open. I’ve sent 17.24 MB and received 26.91 MB. I’ve received 26 connections on IPv4 and 0 on IPv6. I’ve made 16 connections with IPv4 and 0 with IPv6.
tor_proxy | Sep 05 12:28:21.000 [notice] While bootstrapping, fetched this many bytes: 733287 (consensus network-status fetch); 14358 (authority cert fetch); 11915500 (microdescriptor fetch)
tor_proxy | Sep 05 12:28:21.000 [notice] While not bootstrapping, fetched this many bytes: 611991 (consensus network-status fetch); 14523 (authority cert fetch); 1995311 (microdescriptor fetch)
tor_proxy | Sep 05 12:28:21.000 [notice] Heartbeat: Our onion service received 0 v3 INTRODUCE2 cells and attempted to launch 0 rendezvous circuits.
App logs
bitcoin
Attaching to bitcoin_server_1, bitcoin_bitcoind_1, bitcoin_tor_1, bitcoin_app_proxy_1, bitcoin_tor_server_1, bitcoin_i2pd_daemon_1
server_1 | umbrel-middleware
server_1 | ::ffff:10.21.0.10 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/bitcoind/info/connections HTTP/1.1” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
server_1 |
app_proxy_1 | Validating token: d8a868e5112f …
bitcoind_1 | 2023-09-05T15:37:15Z Socks5() connect to 51.174.124.248:8333 failed: general failure
server_1 | ::ffff:10.21.0.10 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/bitcoind/info/stats HTTP/1.1” 200 126 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
bitcoind_1 | 2023-09-05T15:40:39Z New outbound peer connected: version: 70016, blocks=806341, peer=249 (block-relay-only)
bitcoind_1 | 2023-09-05T15:41:59Z Socks5() connect to 2600:6c50:437f:85bc:928:4a29:724c:3067:8333 failed: general failure
server_1 |
bitcoind_1 | 2023-09-05T15:42:21Z New outbound peer connected: version: 70016, blocks=806341, peer=251 (block-relay-only)
bitcoind_1 | 2023-09-05T15:43:22Z Socks5() connect to 172.56.105.52:8333 failed: general failure
i2pd_daemon_1 | 15:49:37@272/error - Garlic: Failed to decrypt message
bitcoind_1 | 2023-09-05T15:43:55Z Saw new header hash=00000000000000000003a444b70366765359ec534ca485b35481d67ea298661a height=806342
bitcoind_1 | 2023-09-05T15:43:55Z [net] Saw new cmpctblock header hash=00000000000000000003a444b70366765359ec534ca485b35481d67ea298661a peer=136
tor_1 | Sep 05 14:55:35.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1 | Sep 05 14:57:40.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
server_1 | ::ffff:10.21.0.10 - - [Tue, 05 Sep 2023 15:49:18 GMT] “GET /v1/bitcoind/info/sync HTTP/1.1” 200 103 “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
i2pd_daemon_1 | 15:49:39@272/error - Garlic: Failed to decrypt message
bitcoind_1 | 2023-09-05T15:43:57Z UpdateTip: new best=00000000000000000003a444b70366765359ec534ca485b35481d67ea298661a height=806342 version=0x31830000 log2_work=94.400662 tx=889604623 date=‘2023-09-05T15:43:45Z’ progress=1.000000 cache=294.8MiB(2084641txo)
bitcoind_1 | 2023-09-05T15:45:14Z New outbound peer connected: version: 70016, blocks=806342, peer=252 (block-relay-only)
tor_1 | Sep 05 15:03:51.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor_1 | Sep 05 15:04:25.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
bitcoind_1 | 2023-09-05T15:46:16Z Socks5() connect to 2xc5ior4k6kra4utuoigdqobggxhxesdchb2o4t27xupmlvqf47ugyyd.onion:8333 failed: host unreachable
tor_1 | Sep 05 15:04:36.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
i2pd_daemon_1 | 15:49:42@272/error - Garlic: Failed to decrypt message
server_1 |
tor_1 | Sep 05 15:06:43.000 [notice] Closed 1 streams for service [scrubbed].onion for reason resolve failed. Fetch status: No more HSDir available to query.
tor_1 | Sep 05 15:28:11.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor_1 | Sep 05 15:29:34.000 [notice] Application asked to connect to port 0. Refusing.
tor_1 | Sep 05 15:41:59.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor_1 | Sep 05 15:43:22.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
i2pd_daemon_1 | 15:49:47@272/error - Garlic: Failed to decrypt message
i2pd_daemon_1 | 15:49:48@272/error - Garlic: Failed to decrypt message
lightning
Attaching to lightning_app_1, lightning_app_proxy_1, lightning_tor_1, lightning_tor_server_1, lightning_lnd_1
app_1 | Checking LND status…
app_1 | [backup-monitor] Checking channel backup…
app_1 | [backup-monitor] Sleeping…
app_1 | Waiting for LND…
app_1 | ::ffff:10.21.0.21 - - [Tue, 05 Sep 2023 15:49:38 GMT] “GET /v1/lnd/info/status HTTP/1.1” 304 - “-” “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36”
app_1 |
app_1 | umbrel-lightning
lnd_1 | 2023-09-05 15:49:44.458 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd_1 | 2023-09-05 15:49:44.458 [INF] LTND: Opening the main database, this might take a few minutes…
lnd_1 | 2023-09-05 15:49:44.458 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd_1 | panic: freepages: failed to get all reachable pages (page 23065: multiple references)
lnd_1 |
lnd_1 | goroutine 197 [running]:
lnd_1 | go.etcd.io/bbolt.(*DB).freepages.func2()
lnd_1 | go.etcd.io/bbolt@v1.3.6/db.go:1056 +0x8c
lnd_1 | created by go.etcd.io/bbolt.(*DB).freepages
lnd_1 | go.etcd.io/bbolt@v1.3.6/db.go:1054 +0x13c
tor_1 | Sep 05 14:49:26.000 [notice] Bootstrapped 55% (loading_descriptors): Loading relay descriptors
tor_1 | Sep 05 14:49:28.000 [notice] Bootstrapped 60% (loading_descriptors): Loading relay descriptors
tor_1 | Sep 05 14:49:28.000 [notice] Bootstrapped 68% (loading_descriptors): Loading relay descriptors
tor_1 | Sep 05 14:49:29.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor_1 | Sep 05 14:49:29.000 [notice] Bootstrapped 80% (ap_conn): Connecting to a relay to build circuits
tor_1 | Sep 05 14:49:29.000 [notice] Bootstrapped 85% (ap_conn_done): Connected to a relay to build circuits
tor_1 | Sep 05 14:49:30.000 [notice] Bootstrapped 89% (ap_handshake): Finishing handshake with a relay to build circuits
tor_1 | Sep 05 14:49:30.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor_1 | Sep 05 14:49:30.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor_1 | Sep 05 14:49:31.000 [notice] Bootstrapped 100% (done): Done
mempool
Attaching to mempool_web_1, mempool_api_1, mempool_mariadb_1, mempool_app_proxy_1, mempool_tor_server_1
api_1 | Sep 5 14:27:11 [128] INFO: Core index ‘txindex’ is synced. Best block height is 806337
api_1 | Sep 5 14:27:11 [128] INFO: Core index ‘basic block filter index’ is synced. Best block height is 806337
api_1 | Sep 5 14:27:20 [128] INFO: Latest BTC fiat averaged price: {“time”:1693846800,“USD”:25695,“EUR”:24317,“GBP”:22184,“CAD”:34954,“CHF”:22849,“AUD”:40326,“JPY”:3794850}
api_1 | Sep 5 14:30:18 [128] ERR: [Lightning] $runTasks() error: Request failed with status code 500
api_1 | Sep 5 14:31:24 [128] ERR: Exception in $logStatsDaily. Reason: connect ECONNREFUSED 10.21.21.9:8080
api_1 | Sep 5 15:28:43 [128] INFO: Core index ‘txindex’ is synced. Best block height is 806340
api_1 | Sep 5 15:28:43 [128] INFO: Core index ‘basic block filter index’ is synced. Best block height is 806340
api_1 | Sep 5 15:28:56 [128] INFO: Latest BTC fiat averaged price: {“time”:1693846800,“USD”:25695,“EUR”:24345,“GBP”:22239,“CAD”:35023,“CHF”:22848,“AUD”:40314,“JPY”:3802375}
api_1 | Sep 5 15:30:06 [128] ERR: [Lightning] $runTasks() error: connect EHOSTUNREACH 10.21.21.9:8080
api_1 | Sep 5 15:31:28 [128] ERR: Exception in $logStatsDaily. Reason: connect EHOSTUNREACH 10.21.21.9:8080
app_proxy_1 | [HPM] Proxy created: / → http://10.21.21.26:3006
app_proxy_1 | Waiting for 10.21.21.26:3006 to open…
app_proxy_1 | mempool is now ready…
app_proxy_1 | Listening on port: 3006
web_1 | /var/www/mempool/browser/resources
mariadb_1 | 2023-09-04 18:28:57 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
mariadb_1 | 2023-09-04 18:28:57 0 [Note] Server socket created on IP: ‘::’.
mariadb_1 | 2023-09-04 18:28:57 0 [Warning] ‘proxies_priv’ entry ‘@% root@c332845d23ac’ ignored in --skip-name-resolve mode.
mariadb_1 | 2023-09-04 18:28:58 0 [Note] Reading of all Master_info entries succeeded
mariadb_1 | 2023-09-04 18:28:58 0 [Note] Added new Master_info ‘’ to hash table
mariadb_1 | 2023-09-04 18:28:58 0 [Note] mysqld: ready for connections.
mariadb_1 | Version: ‘10.5.12-MariaDB-1:10.5.12+maria~focal’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
mariadb_1 | 2023-09-04 18:28:58 3 [Warning] Aborted connection 3 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.27’ (This connection closed normally without authentication)
mariadb_1 | 2023-09-04 18:28:58 4 [Warning] Aborted connection 4 to db: ‘unconnected’ user: ‘unauthenticated’ host: ‘10.21.21.26’ (This connection closed normally without authentication)
mariadb_1 | 2023-09-04 18:29:02 0 [Note] InnoDB: Buffer pool(s) load completed at 230904 18:29:02
==== Result ====
All other apps appear to be working. Out of ideas at this point, so could use some assistance.
Thanks!
