Lightning Node App do not start
Hello, after successfully syncing the blockchain over the last few days, the Lightning Node app still won’t start, the loading bar is stuck at 60%.
I have already restarted LND several times.
Would it do any good to reinstall the app?
Here are the logs:
Did you have any cure for the issue? I have the same issue currently.
Have you solved? Same issue here All app "Starting"... but not starting!
