My umbrel node LND won't start?
Hi there,
Just recently I bought umbrel home 2024. Bitcoin node is 100% sync but my LND node seems to be stuck in starting. I deleted, restart and still nothing. any help?
Just to be sure:
  • you tried to uninstall the app and install it again
  • you tried restarting via web UI
  • LND still does not start
Can you share the logs?
web UI → right click on Lightning Node app → Troubleshoot → Download Lightning Node logs
Correct
see LN logs below
umbrel_lightning_2024-06-17_07-08.log (72.3 KB)
And what version of LND are you using? v0.18.0-beta?
correct
Actually, this is the current Version
umbrelOS 1.2 Beta 2
Are you still having issues after doing all of these steps?
Actually, for some strange reason start working. Not sure what was the issue. It wasn’t working from the moment I connected the Umbrel home.
Any tips for the future if this happens again?
That would be hard to say only because the reason can change. If it happens again, I’d post and then post the logs so the community can take a look at it.
Thank you
