Umbrel constantly keeps disconnecting after 2-3 hours of work. Then it’s not showing as connected to router and I can’t ping it. When I restart raspberry pi 4B, it works for another 2-3 hours.
Are you using Mempool?
Mempool causes lots of connection problems here,
No, just started using umbrel. Bitcoin node still synchronizing.
Do you happen to run your local network with a VPN? Sometimes this can cause issues.
In any case, it may help to set a static IP, you can follow this guide here: How to set a static IP for your Umbrel server
I also find Tailscale to be helpful for networking.
If you continue to have issues, feel free to generate some troubleshooting logs and share them here
You can generate troubleshooting logs from your Umbrel to help diagnose an issue with your device and any apps that you have installed.
To generate logs from the Umbrel web interface:
Access your Umbrel through a web browser
Go to “Settings”
Click “Start” next to “Troubleshooting” to generate the logs
If you are unable to access your Umbrel server through a web browser, you can generate troubleshooting logs from the command line by following these steps:
Connect to your Umbrel server by following the instructions in How to SSH into umbrelOS on Umbrel Home or Rasberry Pi or by accessing a terminal on your Linux machine.
Run the following command. If you are on a Linux machine, you may need to replace ~/umbrel with the path to your installation directory, as described in Troubleshooting on Linux :sudo ~/umbrel/scripts/debug
Bought another SSD, problem solved.
