Hello, I have an ongoing issue with my Rasberry Pi and umbrel. It quits working after about a week to 10 days and then I have to unplug and reboot. Where would you start to figure out the issue? Also, is there a guide to reinstalling Umbrel anywhere. I don’t want to lose my funds.
Thank you!
is the harddrive good and working?
Yes
To get help, you need publish trobleshooting logs…
Here is a great guide Umbrel Troubleshooting Guide
umbrel-1671504136122-debug.log (61.7 KB)
I am not sure what I am looking at. Any help would be greatly appreciated.
You don´t have enough ram memory to run all those apps.
Uninstall the same function apps (ex lnd or c-core, only one wallet, only one btc explorer, etc)
Thank you! Would you mind helping me determine what is duplicate. I am very new to all of this. Thank you!
I recommend you to install only the really necessary apps. BTC, LND, RTL. Try it for a month if everything works. I also used to install too many apps and my Umbrel kept crashing. is worth a try.
