Hello to all Rainmaker,
has someone managed to connect the Joule extension with the Umbrel node?
I get always Message:
Request failed with the message "Unexpected token < in JSON at position 0
Thank you a lot.
Thank you a lot.
The same with readonly.macaroon >
7. Paste hex strings.
8. Connect >
9. Confirm >
10. Create a Password >
DONE!
Sometimes you need to click link when you see message below:
Failed to connect to node
Request failed with the message âFailed to fetchâ
If youâre sure youâve setup your node correctly, try clicking this link and making sure it loads correctly. If there are SSL errors, click âadvancedâ and proceed to accept the certificate.
Than âAdvancedâ and [Proceed to umbrel.local (unsafe)]
Thanks for this @max. Can you change your Pi IP address to umbrel.local instead? So it will work for every user.
@louneskmt canât edit anymore.
BTW
Personally I had an issue with umbrel.local, did not work.
Thank you a lot everything is perfect now!
