Hmm. My IPV6 trick broke Mempool… so even though LND and Bitcoin are running fine, I think I’m just going to force-restore back to 0.3.10 and wait for someone from Umbrel to patch these last two updates. I’d seen that they felt it wasn’t causing the issues on Telegram, but now I think the evidence is too strong given how many of us are having issues.
My problem also started after changing the Alias.
So far (9 hours) after manually reinstalling the update and NOT changing my alias all is still running perfectly
Well, it seems like 0.3.10 and Alias or 0.3.12 and No Alias.
For me, I’ve been down so long now, I’m playing it safe and going with 0.3.10 and no alias. I already dropped 8 spots in the rankings on Lightning Terminal…
add me to the list of having intermittent connectivity issues. Restarting gets it to sync again but doesn’t last long. I have also been fiddling with my Alias, and balance of satoshi, but everything was working fine before this update.
@The_Lorax Do you just rollback to an older version with a terminal command? don’t see that option in the UI.
Update. 2 days after manually reinstalling v0.3.13 my node has the same problems again, sync stopping, unable to access from Macbook but can still access from iphone.
I am running on the recommended hardware and have had zero problems since I set the node up over a month ago. But since this latest update I got constant problems, going to go back to v0.3.10 and see how that goes
