Installing Umbrel os
Hi all, I have a mini pc which I have downloaded umbrella onto and I have got to the umbrel login: screen. My WiFi router won’t show the mini Pc connected to the router so I can’t get its IP address and when I do get the IP address host name -I it will not connect to through a browser on the same network. Help.
I think you can sign-in from that login screen with User: umbrel Password: umbrel
Then, issue: ip a
It should tell you the password that got assigned.
Once you have that … access it from a browser on another computer to get it setup.
Command not found
Are you sure the wifi is connected? Ping google.com and see if it times out.
The mini pc I’m trying to install Imbrel os on is connected to my home WiFi, which a pc, wired, and other appliances, wireless, are connected without issue.
